22-02-2014, 01:06 PM
turning fueling up on bosch pump but the revs go up with it whats going on??
D turbo problem
22-02-2014, 01:21 PM
id only gave it 1 full turn ish and there wasnt much improvement only thing happend was revs went up on idle
22-02-2014, 01:33 PM
(22-02-2014, 01:21 PM)01joelh Wrote: id only gave it 1 full turn ish and there wasnt much improvement only thing happend was revs went up on idle that's what happens mate, have you read the tuning guide on here? . . . .one full turn on the fuel screw is a fcuking lot by the way, also you won't see much improvement without tightening the wastegate on the turbo (increasing the psi) . . . .you need to lower the idle back down using the hot/cold isle screws on the back of the pump . .
You need to drop the idle pretty simple really unless you have run out of idle adjustment then you need to look at other options like grinding the throttle arm or moving it one spline
22-02-2014, 01:37 PM
ive messed with idle screws lowered it down a tiny bit guess only options is tighting the waste gate see what happens then
22-02-2014, 01:38 PM
(22-02-2014, 01:37 PM)01joelh Wrote: ive messed with idle screws lowered it down a tiny bit guess only options is tighting the waste gate see what happens then don't mean to offend you mate but you clearly need to do a bit of reading up . . . what did you expect to happen from just turning the fuel up? . .
22-02-2014, 01:40 PM
ive read up a few guides and the say you can turn it few turns so wondered what heck was going on when i turned one turn and i ended up with high revs
22-02-2014, 01:42 PM
(22-02-2014, 01:40 PM)01joelh Wrote: ive read up a few guides and the say you can turn it few turns so wondered what heck was going on when i turned one turn and i ended up with high revs how high are the revs? . . . .what i mean is you won't really get any more power from just turning up the fuel, you need the extra boost to burn it or you'll just smoke every fcuker out and fcuk your car up . .
22-02-2014, 01:43 PM
say a turn and abit and it was on 2000 revs
22-02-2014, 01:45 PM
(22-02-2014, 01:43 PM)01joelh Wrote: say a turn and abit and it was on 2000 revs like i said to you one full turn is a lot, plus you're not to know that it hasn't already been turned up, have you got a boost gauge because you need one, how much boost is she running?
22-02-2014, 01:53 PM
(22-02-2014, 01:40 PM)01joelh Wrote: ive read up a few guides and the say you can turn it few turns so wondered what heck was going on when i turned one turn and i ended up with high revs No guides on here will say to turn it a FEW turns!!! One turn is a lot. Drop the idle screw right back. But I would do a quarter turn at a time, and similar amount on the wastegate arm, and with a boost gauge and a empty road get the levels right that way. Done any supporting mods? Wishes for more power...
22-02-2014, 01:54 PM
the seal was on the screw still snapped it off... its running after i fiddled with it about 14psi ive got it to
22-02-2014, 01:55 PM
(22-02-2014, 01:54 PM)01joelh Wrote: the seal was on the screw still snapped it off... its running after i fiddled with it about 14psi ive got it to well you need to sort the turbo next, do you know which one you've got?
22-02-2014, 01:56 PM
yer the kkk one
22-02-2014, 02:00 PM
(22-02-2014, 01:56 PM)01joelh Wrote: yer the kkk one k14 yeah, ok well that's easy to adjust, undo the locknut, then put and allen key through the socket still on the locknut and tighten the wastegate all the way in, then just back it off a little bit, tighten the locknut by hand while still holding the allen key and then nip it up the last bit with your ratchet . . . ![]() that's more or less with a couple of other bits what got me the dyno results below my sig picture . .
22-02-2014, 02:23 PM
This is from the bosch guide dan put up
Quote:3. Fuel screw Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
22-02-2014, 03:29 PM
well i bet i didn't turn mine in much more than a full turn to get where i am now so go figure . .
22-02-2014, 03:47 PM
I highly doubt your having issues controlling the idle you just dont know what your doing lol. If the idle screw is all the way out then you need to wind the minimum throttle travel screw out, or is it the other way round? Meh who cares. Then if your idle is still high can can look at chopping the pump up and bending shit. But i really really doubt your anywhere near that point.
24-02-2014, 12:36 PM
Well I've tighten the wastegate up and gauge says 20psi plus but it doesn't seem to me pulling a lot
| Problem turbo pressure gt2056s | niciou | 6 | 6,645 |
30-03-2017, 06:41 PM Last Post: niciou |
| oil problem after turbo change | willJspears | 15 | 7,504 |
27-01-2014, 01:24 PM Last Post: willJspears |
| possible turbo problem? | willJspears | 5 | 3,429 |
27-11-2013, 08:37 AM Last Post: willJspears |
