Urgently needed, hdi inlet elbow studs
Wanted: Urgently needed, hdi inlet elbow studs
Replacing the leaking inlet elbow gasket on my hdi on the weekend, managed to snap the Bastard stud so can't get a nut on the one to tighten the elbow to the inlet manifold, que chronic boost leak
Anyone breaking an hdi engine or happen to have a spare inlet manifold lying about that I can have the studs out of?
There the two that hold the elbow to the inlet manifold with two 13mm nuts.
Urgently needed as the car sounds like a bloody kettle and drinking fuel like a '6 :-(
Just use an m8 bolt? If you got the stud out
(17-02-2014, 05:20 PM)Chris_90 Wrote: Just use an m8 bolt? If you got the stud out
Il give it a go
Worth a try even for temporary why you get some studs Smile
Will 110 hdi ones be the same? If so I have a set
Team Doesn't own a 306
Ive got a spare engine sat in the garage, only in Stroud so not too far to come and get them.
  2.0 HDi inlet elbow Uberderv 7 7,018 16-01-2019, 06:20 PM
Last Post: Frosty
  406 / c5 top pipe and inlet elbow Hdi and proud of it 3 2,476 04-06-2015, 10:37 AM
Last Post: Matt-Rallye
  Wanted: Urgently needed: Full exhaust system for Rallye. Matt-Rallye 3 2,480 28-04-2014, 10:42 AM
Last Post: welshpug
