Driveshaft bearing
Off to look at hdi tomorrow that is making a grinding noise been told its either a cv joint or a bearing
driveshaft swap should be a doddle but are the bearings easy to do ?
ebay driveshaft complete is only £35 delivered
Well the only bearing for thr driveshafts are the one on the lower engine mount...dont normaly go noisey though.
And CV joints knock, they dont grind.
Theres a video of it ill post it in a sec
see what you make of it Smile
http://youtu.be/SzYrcRQ1Q_Q
there it is
Thats horrific whatever it is!
That's almost certainly the CV joint.
CV will only really make noise on full lock, that far more likely to be the driveshaft bearing. it will have shattered like wheel bearings do
(14-02-2014, 10:46 PM)Daniel306 Wrote: CV will only really make noise on full lock, that far more likely to be the driveshaft bearing. it will have shattered like wheel bearings do
They hard to do ?
From experience it only takes a small turn to get a CV knock...but does depend how bad it is....and that sounds pretty bad lol.
To fit the new bearing it needs to be heated with a blowtorch and pushed on the shaft, as it cools it contracts again and 'locks' onto the shaft.
Just fit another shaft, has the bearing on it
[Image: av5ym8.jpg]
(14-02-2014, 11:00 PM)Jimbo Wrote: Just fit another shaft, has the bearing on it
Seems the best option Smile cheers
Cv joint can knock in s straight line if the joint is near collapse. It'll chew its self up eventually which sounds pretty much like that, drive shaft its self is easy enough to change once you'v got the hub nut off and ball joint out the hub. Remember to drain the gearbox and refill or catch what you loose beacuse once u pull it out the box itl piss out. New shaft will include both inner and outer c.v joints and bearing so if its one or the other it should cure it.
(14-02-2014, 11:04 PM)JJtheHITMAN Wrote: Cv joint can knock in s straight line if the joint is near collapse. It'll chew its self up eventually which sounds pretty much like that, drive shaft its self is easy enough to change once you'v got the hub nut off and ball joint out the hub. Remember to drain the gearbox and refill or catch what you loose beacuse once u pull it out the box itl piss out. New shaft will include both inner and outer c.v joints and bearing so if its one or the other it should cure it.
Sound cheers man Smile
Get ya hand under and grab the shaft(!) And twist.
You should feel if it is a shaft and which one
Thats the sound of the bearing locking up, if it was a CV there would have been a video 12months ago asking "whats this clicking on full lock?"
jackup the drivers side and try spin the wheel round
(14-02-2014, 11:00 PM)Toms306 Wrote: From experience it only takes a small turn to get a CV knock...but does depend how bad it is....and that sounds pretty bad lol.
Roast the bearing? have you done this before, how long did it last?
Its not his car, its one he's going to look at.
I didn't do it, I'm not trusted with fire... Though I've seen it done, you don't want to cook it, just heat the inner race to expand it, only takes a few seconds of heat.
Hot enough to make it expand would destroy it. I phoned peugeot and a few motor factors years ago, no where would sell the bearing on its own
Only going from my own experience...and it seemed to work fine.
Also, you didn't try hard enough. Tongue http://www.ebay.co.uk/itm/Peugeot-306-Dr...4897.l4275
Not worth the hassle, I have just recently changed my drivers side drive shaft and got a new shaft from here, and it was just under 40 quid delivered And it arrived the next day.
http://www.jandrcvjoints.co.uk/search.ph...235&y=-362
Also worth looking at changing the seal to as once they have been disturbed then tend to leak. I got one from the local pug dealer for about 12 quid. Worth changing as if it leaks the shaft has to come out again and some of your nice new gearbox oil will end up all over the floor.
1 for £12. Undecided I think they cost us about £4 for the pair from ecp.
1s from peugeot are a fair bit more than most motor factors etc
J and R are very good quality. I bought a Q-drive one from ECP (£80 after discount!) then 2 months later the other driveshaft went and I spent £40 at J and R. The quality seemed better on the latter one!
[Image: Sig500x130.png]
(15-02-2014, 08:10 AM)Poodle Wrote: 1 for £12. Undecided I think they cost us about £4 for the pair from ecp.
I went to my local ecp and as usual they didn't have them in stock, so i got it from the local pug dealer when i got my new gear box oil.
Bought the car now Smile
driveshaft for 30 quid from a local parts store
  Driveshaft Intermediate Bearing Problem Toms306 7 3,412 19-04-2014, 12:24 PM
Last Post: Toms306
