Threads: 186
38
Car Model/Spec: MG ZR VVC
The area around it needs tcutting anyway due to a bit of primer making it past the masking off. at least now there's some paint on the area so it might fool someone for a second or so. Going to take some time to blend it I think
Threads: 82
27
Maybe cheaper to vinyl wrap the roof? Places down here only charge £60 for a roof wrap and it will probably look tidier than a rattle can job
Threads: 170
Told you not to spray up to the tape lol.
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 151
14
Car Model/Spec: 306 D-turbo
Wet sand it down buff if up and laquer
Team Doesn't own a 306
Threads: 186
38
Quick photo of the paint, the match is pretty darn close just need to smooth out the line. Tried some cutting compound on it earlier which removed the oversprayed primer but blend the edged just too the paint off. Also got some 2000 grit paper which I'll try with warm soapy water tomorrow to smooth out the paint before laquering
