Threads: 581
195
After installing my new loom and ECU, my rev counter no longer works. The original loom has been stripped right down to just supply the dash only (stripped too far i guess!). Where does the rev counter take its signal from? Straight from the ECU? Anyone got any idea of wire numbers so i can go hunting for the right cable?
Threads: 465
114
Car Model/Spec: Vauxhall
You already asked that question
Search for engine speed sensor
Threads: 581
195
So i did. I must be getting old. Forgot about that! Now, why the hell doesn't it work!! lol
Threads: 581
195
Yeah I've got that. Just can't work out why it doesn't work. The Omex should just wire directly up to 465 and it should work
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
Is the output signal from an Omex ECU known to be compatible with a standard unmodified GTi-6 tacho?
