05-02-2014, 08:13 PM
I can arrange an RR meet, in Barnsley
Citroen Berlingo 1.9DT - For Sale 10 month MOT £650 ono
05-02-2014, 10:06 PM
Still needs a V8.
06-02-2014, 09:56 PM
(This post was last modified: 06-02-2014, 09:58 PM by Jenkosowls.)
(05-02-2014, 11:28 AM)ozonehostile Wrote: Is that my old pump? Yup your old pump bought it agesssss ago! (05-02-2014, 05:51 PM)Sambarker Wrote: When u arranging another rr meet RR meet probs just be a yearly thing die to Clive doing his racing through the better weather months Vans quite lively technically it's it's double power! It feels allot more lively 0-60 is pretty quick. Enjoying boosting again!
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
11-03-2014, 11:31 PM
(27-12-2013, 11:10 PM)Jenkosowls Wrote: Also fully fitted ph3 306 seats they a straight fit then? or modified to fit? ![]() TEAM CONROD SHITTING RALLYE!
11-03-2014, 11:36 PM
Modified to fit fairly easy you use the base of the berlingo seats get rid of the 306 runners then bolt it in. 306 seats have 4 holes you can use to bolt it down to one of holes is covered by tube . Fairly straight forward takes an hour or do to do aseat
11-03-2014, 11:50 PM
ahhh sweet not too bad then. pretty cool that they fit, didnt think they would. bit of home comfort eh?
11-03-2014, 11:58 PM
(22-08-2013, 07:18 PM)Jenkosowls Wrote:(21-08-2013, 08:19 AM)mr_fish Wrote: i think black blends in a bit too much. so +1 for silver... or what about a silver lip on the black wheels to break it up a little (and to be different). What p bushes did you have before, 306 ones or berlingo, I'm just trying to work out what size bolt I need to kit berlingo bushes to a 306 - any ideas? ![]() the smokey old bus that sounds like a tractor...
12-03-2014, 11:09 AM
it was a standard 306/zx pbush
12-03-2014, 12:10 PM
(12-03-2014, 11:09 AM)Jenkosowls Wrote: it was a standard 306/zx pbush So what bolt did you use to fit the bush to the car as I understand it's a m10 not m8 as per std p bush? Do you have sizes so I could get a pair of bolts?? ![]() the smokey old bus that sounds like a tractor...
12-03-2014, 12:30 PM
that ain't no DPF, its a cat.
12-03-2014, 01:12 PM
I believe its m10x1.5
12-03-2014, 01:21 PM
no, 1.25.
just buy the bolts from pug whilst you're ordering the bushes.
12-03-2014, 05:54 PM
These ones wasn't from peugeot in the first place but I'd tapped mine out to 1.5 as that's what I had available. My mistake!
12-03-2014, 07:48 PM
(This post was last modified: 12-03-2014, 08:16 PM by devils_fuel.)
(12-03-2014, 01:21 PM)welshpug Wrote: no, 1.25. Thanks mate, do you happen to have a part number so I am get them as I don't have pug planet These any good? http://bit.ly/1iBqtM8 ![]() the smokey old bus that sounds like a tractor...
12-03-2014, 08:30 PM
(This post was last modified: 12-03-2014, 08:31 PM by devils_fuel.)
Ah just saw this thread, are these the correct dimensions?
Bolt search http://www.306oc.co.uk/forum/showthread.php?tid=20503 ![]() the smokey old bus that sounds like a tractor...
12-03-2014, 09:25 PM
Should be M10x1.25, but Jenks has hit his head one too many times.
12-03-2014, 09:27 PM
(12-03-2014, 09:25 PM)Rippthrough Wrote: Should be M10x1.25, but Jenks has hit his head one too many times. Ripp you legend, is it fine thread, what collar & bolt length?? ![]() the smokey old bus that sounds like a tractor...
12-03-2014, 09:49 PM
Not certain but 16mm rings a bell.
19-06-2014, 07:14 PM
well its been a while...
Engines being a typical xud plenty of abuse and boost. currently not sure what psi im running etc litterally stock k14 turbo with fuel turned up a tad. its nippy and pulls me up the hills! Made myself my own upper strut brace with master cylinder stop rippthrough thinks its a master piece.. but with the M/C i can now feel the van breaking well i could after i swopped the calipers over seen as though one side had seized on its slider pins effectively making it useless! only issue is due to making it a tight fit on the intercooler and shagged engine mount the engine taps on it in reverse. P-bushes both mine have failed. This could be down to many aspects rallying down gravel farm tracks? heavier pay loads? bad fitment angle? odd collision with curbs? or Shit rubber? Il never really know but probably a combination of all of them. either way after talking to Ripp he pointed out that it appears pug have superceded the old design for the new design on service box quick look and low and behold they have £44 later i now have a genuine set of new design bushes. going to get some front bushes two was going to get lemforder but ecp are out of stock. Gearbox oil. mines pisses it out for fun after changing engine these were the last thing on my mind. must have used around 6l of fluid. first good oil 2nd what ever the f*ck i could find in the work shop most likely tractor gearbox or beam axle fluid 3rd lot Rippthrough special of mix those 2 together haha! any way iv actually order some genuine seals to and putting in some castrol syntrans oil in for good measure! going to buy a new engine mount push that in and for sake of a fiver do the litlle bush also! learned my lesson from the nice billet ally bush so oem for me just rotate it around. last but not least recently purchased some cyclones of mr cheese and put brand spanking Rainsport 3's on all four corners. literally do believe this is the first car iv owned with brand spanking new tyres all round! so yeah vans getting some love for once. [attachment=16972]
20-06-2014, 07:50 PM
The vans looking good fella
09-08-2014, 09:07 PM
so Ebay bushes didnt last long for me
![]() so bolted some crap on sorted few things but others still remain the same. Drop Links = Solved Gearbox seals = really dont f'**ing know Arb Bushes = Solved Cv Boot = Solved Rear Engine Mount = Solved Wishbone Bushes = Solved Back Box = Solved Chronic oil leak = cant be F**king Arsed Water Leak = Solved ![]() ![]() ![]() ![]() ![]() And here is one for the farmers ![]() so yeah vans a piece of S**t But it always is come MOT Time
09-08-2014, 09:19 PM
Shes looking good mate.
10-10-2014, 08:03 PM
(11-03-2014, 11:36 PM)Jenkosowls Wrote: Modified to fit fairly easy you use the base of the berlingo seats get rid of the 306 runners then bolt it in. 306 seats have 4 holes you can use to bolt it down to one of holes is covered by tube . Fairly straight forward takes an hour or do to do aseat That the same for the passenger one? did yours have the lift up seat with cubby hole underneath? ![]() Midnightclub Wrote:All the cool kids have ph 2 Nile 6's!
11-10-2014, 12:14 AM
Yup same as the drivers side. Only easier as you don't have to take the whole base out.
23-10-2014, 10:04 PM
(This post was last modified: 23-10-2014, 10:18 PM by Jenkosowls.)
Mot has been and gone passed with no advisories that said id told the MOT tester what was wrong with the van in the first place most of which he said it wouldnt fail on. But the place i took it to is a regular customer and so seat full of parts and trust it passed.
couple of days later.... ![]() few niggles with the van that all mounted up to it being easier to pull the engine and do it all out of the van and tidy things up. so first up sorting the rusty wings not an MOT failure but rust spread so out it came and in went new. Welded on both sides and seam sealed. Bit of a comman problem on these vans due to PSA For some strange reason not seam sealling from the turrets forward. ![]() ![]() Engine bay washed off ![]() Seam Sealed ![]() ![]() Then just to make sure undesealed the underside ![]() Under sealed and painted up ![]() So onto the engine side of things Engine partially stripped to replace Head Gasket Steam Seals Fire seals Copper Seals Sump re seal rocker cover seal Crank seal fly wheel crank seal aux side cam seal HDi bolts Basicaly new seals all round also replaced gearbox seal again ![]() ![]() ![]() ![]() All built back up ![]() Then all back together. ![]() So engine has been running great but still had slight water usage. Which was one reason why i decided to do the engine overhaul. i did notice also radiator has slight leak so sorted a new one. Few Days Later still minor water usage but now a sweet smell and misting windows! so yup heater matric was an issue also suprisingly easy to do on these done with 3 hours ![]() also while dash was out sorted the interior iluminations which suddenly had stopped few months ago ![]()
23-10-2014, 10:26 PM
Nice work.
Nice to see a good bit of tidying done. Guna be the best blingbling out there! Wishes for more power...
28-10-2014, 12:12 AM
Now up for sale! Have i have a new bigger van so this is no longer required price may seem high compared to 306's but this has a completely different market and has had allot of major work done recently. ideal for a 306 owner as the front end on wards is pratically a 306.
Here i have my trusty Citroen Berlingo 600 LX van. Its on a 1999 S reg and has a lot of major work more than your usual ebay "major" work. Its currently on 153,000 miles i purchased it around 122,000 its a diesel peugeot citroen engine which last for 100,000s of miles. iv looked after it and serviced it on regular occassions including twice on its current engine alone this year. The engine in this van has been changed from the DW8 slow straight diesel engine to a Xud Diesel turbo engine around Febuary at 130,000 ish miles. The XUD9TE which is one of the PSA groups best engines there simply to run fix and maintain using no ECU or fancy electronics. The engine in standard form runs at 89bhp this one has most likely got a little more oomph behind it due to minor tune up.why PSA didnt put this engine in these van in the first place i dont know as the straight diesel engine is gutless up hills. The XUD shares the same mounting points gearbox wiring as the original engine the DW8 is a little more modern engine sharing the same xud bottom end. The XUD engine is simply plug and play and 100% safe. Before the swop the XUD engine had new cambelt new tensioners and waterpump and aux belt as well as a service including oils and filters. It currently has mot untill 26th of August 2015 no Tax Due the recent stupid law The vehicle is mechanically sound and will prove to be a reliable workhorse for the next owner. In September this year i recently did some major work inlcuding sorting some rust issues that most of these vans are now facing main one being in the front wheel arches although not an MOT Failure its best to stop the spread. The engine was removed and both front wheel arches had the rotten metal removed to good metal, rust converted then new metal placed and welded on both sides. More rust converter applied to the whole front end, Seam sealed then undersealed and painted. The engine while out had the following done to it New timming side crank seal New flywheel side crank seal New Cam Seal New Rocker cover seal New valve stem seals New Headgasket New HDi head bolts New Cambelt Head skim Valve clean and polish New lower coolant block and gasket New oils and Filters Gearbox had new drive shaft seals and oil Also had a new thicker DT Radiator The tensioners and water pump hadnt covered many miles and still in perfect condition so were reused only covering 7,000 miles of ther 75,000 mile change interval. In effect the engine had a good overhaul that wouldnt need to be done for many 1,000s of miles even over 100,000 miles! This van can run on 100% veg oil and i have done for many 1000s of miles treating it to diesel as well This is down to the Bosch mechanical fuel pump. On most occasions it ran a mix of both providing good performance as well savings. You can get Veg oil as little as 65p a liter for new or 30p for filtered used and all perfectly legal. The front suspension arms have been overhauled having had new ball joints when first purchased and recently had genuine peugeot updated rear p bushes the front bushes were replaced with pattern part ones as well as droplinks and anti roll bar bushes. there ar no knocks or bangs on this van and wont for a while to come. Internal Inside iv fitted after market remote central locking, recently replaced the blower motor and heater matrix after a leak. It is ply lined with ply bulkhead and speakers. It has a heavy duty rubber floor in the rear as well as darkened windows and window guards. The front seats have been replaced with ones out o a 306 and are supporting and comfortable. I have also fitted a Multi space upper self in the front cab for more storage. External The van isnt in the best of conditions as these vans do dent easily. The van prior to me hadnt really been looked after iv smartened it up allot reviving the paint. The van has had areas of filler on the drivers side but is strutually safe never been an issue or concern to me. being 100% honest here with a little bit more attention and time it can look good. But the bonus of the van is the important bits are mechanically sound. The Van is sat on 15" 306 cyclone alloys with Uniroyal Rainsports 3's one of the best wet tyres you can get and have covered less than 3,000 miles. Given the mot and recent work done to it in september i am asking for offers around £650 this van is future proof and major know problems like the rust sorted properly. The recent overhaul of the engine will prove to be a reliable for many years yet again making the van future proof this van wouldnt need servicing for another year! Viewing is welcome and encouraged. Test drives will be done by myself as your insurance will highly likely not cover you to drive this vehicle due to it being comercial. You can drive the vehicle with the correct insurance proven and with full cash amount in my hands. The vehicle is what earns me money so no risks will be taken with out both. All Stickers will be removed before sale and van given a once over for the new owner. van would make a good sleeper project or just an honest nippy work horse. Reason for selling is due to needing a bigger van to which is sat waiting to be used. Project thread/progress can be viewed here http://306oc.co.uk/forum/thread-14516.html
28-10-2014, 10:31 AM
Moved to cars for sale. Good luck mate, seems very cheap for the amount of work you've put in
| For Sale 2.1 xud Citroen xm auto | James | 4 | 3,429 |
11-03-2016, 07:00 AM Last Post: James |
| 2000 Citroen Berlingo 1.9D With Bosch Pump! | Jenkosowls | 2 | 2,768 |
18-07-2015, 11:28 PM Last Post: Jenkosowls |
| FOR SALE: Citroen Berlingo 1.9DT - SOLD | Jenkosowls | 13 | 7,257 |
02-11-2014, 10:06 PM Last Post: Jenkosowls |
