what axle bearings
what axle bearings
what axle bearings do you need to rebuid one?
[Image: cornishmafia.jpg]
Most the time when you can see camber you will have to replace to shaft that the bearings go on to as well.
I've bought some of ebay to replace mine but mine doesn't show any camber I just thought I'd replace them for peace of mind as they've done 300k+.
Tbh best off buying complete kit.
Bearings seals and tubes
Search ebay for 306 axle bearing kit
[Image: av5ym8.jpg]
is this what I need?
http://www.ebay.co.uk/itm/REAR-BEAM-AXLE...53f04c69af
That's the ones but you'll need a BF press to the shafts out.
You only need about 8-10tonne to press shafts out.
I'd get a S/H beam, rebuild that and swap over, QUite often the tubes have had it too making you car off the road for a while
by the way that is only the kit for one side
  GTi6. beam bearings and stub axle measurements Ben_w 14 6,684 01-06-2015, 05:22 PM
Last Post: Ben_w
