307 battery removal
Everywhere i read says that the 307 bsi needs to be put into sleep mode before i remove and refit the battery, the problem is that the manual says to leave the window open and i dont really want to. i was thinking that i could close the door latch making it think the door is closed and do the procedure that way? think that will be fine?
PROCEDURE FOR BATTERY DIS-CONNECTION (The 3 Minute Rule)
Whenever a vehicle battery has to be dis-connected, switch off all equipment,
interior lights etc, close the doors leaving the drivers window open.
Switch off the ignition and remove the key and any DIAG equipment.
Wait a full 3 minutes before disconnecting the battery.
The BSi must be allowed to go to SLEEP i.e. into "power save mode". Do not
operate any equipment on the vehicle during this time. Remember, even
opening the bonnet will wake the BSi on a vehicle fitted with alarm.
If the battery is under the bonnet, open the bonnet first and leave it up. 807
batteries can be dis-connected through the drivers window, remove floor cover
first. (note, Pics are under the passenger seat)
ALWAYS disconnect any DIAG equipment and do not operate any plips from
other vehicles during the 3 minute waiting period.
PROCEDURE FOR BATTERY RECONNECTION
Unless otherwise instructed by Product Service, you must always
carry out the following procedure, often referred to as a "soft re-boot", to
minimise the possibility of the BSi corrupting its own software when
reconnecting the vehicles battery supply.
Ensure the procedure for battery disconnection has been adhered to and
importantly all BSi functions were switched off with the drivers window left
down.
1 Close all doors
2 Remove ignition key if left in ignition
3 Reconnect battery. DO NOT open any doors
4 Wait 10 seconds
5 Switch on headlights through the drivers window (you will hear a "bong") (note: Snap-on says Side-lights)
6 Switch on ignition then start the vehicle and check system functions
NOTE: Upon reconnection, if any vehicle function controlled by the BSi i.e .
interior light is switched on,the internal operation of the BSi has the potential
to spike or corrupt its configuration and software program......
All that but leave the window up but the door open and the catch shut so it thinks the door is shut
Take my dads battery out all the time on his 307. Keys out, bonnet up, drives door open, all electrical equipment off. Wait 5 mins, remove battery.
Once it's out you can close door etc but if you intend to put it back in, open the door before you do because when you put it in you need to follow the wait 10secs, key ignition and ign on for 10 then remove key and check things like windows etc
[Image: 20gh7o0.jpg]
