22-01-2014, 01:24 PM
Hi all wonder if anyone can help iv been told by a tuning company that they can give me 15-20 more bhp if i was to have a remap and a gain in fuel Ecconamy I'm a bit dubious myself
Remapping my 6
22-01-2014, 01:43 PM
What was this tuning company? Sounds to me like one of these generic ones that's just a load of shite.
22-01-2014, 02:10 PM
22-01-2014, 02:27 PM
22-01-2014, 02:32 PM
Complete the following well known phrase:
"If it sounds too good to be true......" Put simply, the mapping is pretty good as standard and there simply isn't anything like 15-20hp to be gained from optimising on an otherwise standard / standardish car. Remember, considering it's the best part of 20 years old, 167hp was a very respectable output from an NA 2.0 litre engine when you consider that it's got pretty mild cams, no VVT, and emissions nonsense like catalyst.
22-01-2014, 06:37 PM
Yeh im not sure with a 6 youd get much more without supporting mods. How much did they say it would cost? To map it properly youd probably have to get a stand alone ecu.
22-01-2014, 06:39 PM
22-01-2014, 07:17 PM
(22-01-2014, 06:39 PM)Carlos182 Wrote:(22-01-2014, 06:37 PM)SRowell Wrote: Yeh im not sure with a 6 youd get much more without supporting mods. How much did they say it would cost? To map it properly youd probably have to get a stand alone ecu. yes. by going to 1 specific person in one specific area of the country. I believe its based on a P1 map in order to raise the limiter.
22-01-2014, 10:11 PM
If there happy to prove it then do it with a no gain no payment method, But make sure it's on a independent rolling road thou as the Figures are dead easy to adjust. Bet they'll change there mind then. Even Superchips only claim 12bhp
22-01-2014, 10:36 PM
(22-01-2014, 07:17 PM)SRowell Wrote: yes. by going to 1 specific person in one specific area of the country. I believe its based on a P1 map in order to raise the limiter. P1 map, eh? Mine is a Ph3, fully custom mapped. You can set the rev limit to whatever you like upto iirc, 8160 (255x32) as it's the max the ECU can reference. The Marelli ECU as used in the '6 is perfectly able to be remapped for big injectors, boost, throttle bodies, cams etc... everything. JP
JP
23-01-2014, 10:10 AM
Thanks for all the advice lads iv spoken with the. Implant they said they have done 40 gti 6 lol over the years but can not produce any evidence of dyno figures so I will will not be having my car mapped
23-01-2014, 10:21 AM
As standard there not alot you can gain when compared to mapping a standard turbo diesel.
23-01-2014, 04:09 PM
You probably will gain nothing, maybe at a push 1 or 2hp, if you set the cam timing slightly advanced, a touch of spark advance and map it to run on premium juice...
JP
JP
23-01-2014, 05:24 PM
I have a mysterious ecu which takes it up to around 192 bhp thats just the ecu!
23-01-2014, 08:43 PM
(23-01-2014, 05:24 PM)Sian Wrote: I have a mysterious ecu which takes it up to around 192 bhp thats just the ecu! That just sounds dodgy tbh. 190 is ITB territory!
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft (23-01-2014, 08:43 PM)Niall Wrote:(23-01-2014, 05:24 PM)Sian Wrote: I have a mysterious ecu which takes it up to around 192 bhp thats just the ecu! How is it dodgey? Its the ecu adam got of his old boss with the maxi! Its a genuine unlocked one! its not a cheap fix! I dont know alot about it only that it is great fun ![]()
25-01-2014, 07:47 PM
So a totally stock motor, with a different ECU is putting out 190hp? Yeah, sure...
JP
26-01-2014, 10:40 PM
Its a n class ecu or something i dont know alot about it except adams boss had it in for rallying as he has had it in alot of gti6s. Not trying to argue with anyone etc but its was prooven by dyno end of
26-01-2014, 10:58 PM
dyno's are easily adjusted to show different outputs.
Im not arguing about it boys! It wasnt adjusted or mucked about with so shh!
27-01-2014, 10:34 AM
Ok, so it's a totally stock engine?
How does the ecu get round the laws of physics?
JP
27-01-2014, 06:42 PM
I do not know! Did say that. Like i said his ex boss used to rally gti 6s and he used it all the time with that ecu! I know when i plug it into mine it bypasses the immobilser and works . Tried it in the ph3 gti 6 i had and it wouldnt start. Its for ph1s
27-01-2014, 07:02 PM
(27-01-2014, 06:42 PM)Sian Wrote: I do not know! Did say that. Like i said his ex boss used to rally gti 6s and he used it all the time with that ecu! I know when i plug it into mine it bypasses the immobilser and works . Tried it in the ph3 gti 6 i had and it wouldnt start. Its for ph1s It was 190 odd hp on his engine, not yours. ![]() In the same way, that plugging a GTI-6 ECU into an XSi works, engine appears to run normally. I did it for months, but it didn't give it 35hp+
28-01-2014, 01:53 PM
Maybe I should put my low boost mapped ecu without the supercharger on my engine and I'll have 250+bhp...
Could have saved some money.
28-01-2014, 06:20 PM
(28-01-2014, 01:53 PM)luke306rallye Wrote: Maybe I should put my low boost mapped ecu without the supercharger on my engine and I'll have 250+bhp... Shhh don't tell Niall the secret!
28-01-2014, 08:27 PM
Oh Shit
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft (27-01-2014, 07:02 PM)Martin306 Wrote:(27-01-2014, 06:42 PM)Sian Wrote: I do not know! Did say that. Like i said his ex boss used to rally gti 6s and he used it all the time with that ecu! I know when i plug it into mine it bypasses the immobilser and works . Tried it in the ph3 gti 6 i had and it wouldnt start. Its for ph1s Didnt say on my car did i! Although ive never put it on the dyno with it on ! But the throttle response is alot better with that ecu then the original! It doesnt work in a xsi ! Ive put it in the xsi it wont start its a 8v ! (28-01-2014, 01:53 PM)luke306rallye Wrote: Maybe I should put my low boost mapped ecu without the supercharger on my engine and I'll have 250+bhp... You obviously wont get that sort of gain as a super charger ! That a stupid comment! Im merely saying a gain of around 25hp maximum !
29-01-2014, 12:43 AM
(28-01-2014, 10:50 PM)Sian Wrote:(27-01-2014, 07:02 PM)Martin306 Wrote:(27-01-2014, 06:42 PM)Sian Wrote: I do not know! Did say that. Like i said his ex boss used to rally gti 6s and he used it all the time with that ecu! I know when i plug it into mine it bypasses the immobilser and works . Tried it in the ph3 gti 6 i had and it wouldnt start. Its for ph1s It works in a 16v XSi though ![]() you bite too easily ![]()
Remapping | PocketFighter | 4 | 1,711 |
13-12-2014, 10:41 AM Last Post: impotentials |
