Wheel Hub/Knuckle
Wheel Hub/Knuckle
Hi,
Does anyone know if the hub/knuckle from a phase 2 dturbo will fit on a phase 1 dturbo?
Thanks.
[Image: 306_zpsadcff53a.png]
The ball joint hole might be a different size, but apart from that I believe they're the same.
If your car has ABS you'll need to check that the replacement hub is an ABS type (preferably with an undamaged sensor as they're often difficult to remove without damaging them and genuine Bosch replacements aren't cheap)
