xud box stuck on release bearing
I've an engine on the ground and the box is stuck on the release bearing, all bolts are loose any ideas on how to get it unstuck?
You need to remove the clutch arm if the shaft so it can turn as the thrust bearing is attached to the clutch
does the pin on the arm push out or pull out?
pull, you'll never push it out due to the casing...
if all else fails, just bend the arm.
Or if your putting a new clutch on wedge a bar inbetween box n block and force it off lol
  Anyone got a clutch release arm lying around? Chairchild 6 4,184 04-01-2015, 10:14 PM
Last Post: Chairchild
  Clutch release bearing alignment. Marcus1991 8 6,934 01-04-2013, 01:25 PM
Last Post: Marcus1991
