22-02-2012, 09:17 PM
What do I need?
I've seen a mount, and a bracket? Do I need both to do it?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
Replacing a gearbox mount
What do I need?
I've seen a mount, and a bracket? Do I need both to do it? ![]() TEAM CONROD SHITTING RALLYE!
22-02-2012, 09:20 PM
Matt careful you get the right size. They do two different sizes that look identical!
Other than that, it's easy. Battery box out, jack under the box, undo the 3 bolts and carefully let the jack down a bit then whip the old one off and fit the new one.
22-02-2012, 09:23 PM
What size should I be looking for? Looking at ecp they list a few for my reg :/
22-02-2012, 09:26 PM
Mine was the bigger one so would assume you need the same. Smaller is for the TU engines IIRC
22-02-2012, 09:28 PM
Okay and I need just the mount yeah? No bracket?
22-02-2012, 09:29 PM
Ye as said tu engines have smaller brackets, that's why I had to get a gti bracket!
22-02-2012, 09:44 PM
Just the mount Matt. It just sits on the bracket that's welded to the car
22-02-2012, 09:51 PM
Ahhh I see, never even seen the mount before so didn't know the. Racket was welded to the car. Hopefully going to pick up some mounts an replace them on Saturday
![]() ![]() TEAM CONROD SHITTING RALLYE!
22-02-2012, 09:57 PM
Well let me rephrase that. The bracket SHOULD be welded to the body. Lol
You doing all the mounts?
22-02-2012, 09:58 PM
Top two at the moment and lower when I have more time/decent trolley jack
22-02-2012, 10:13 PM
Foxy-jim Wrote:They aren't welded just bolted on!The bracket that it bolts to is welded to the body on the XU.
22-02-2012, 10:25 PM
In which case, what holds your battery up? The more superior engine one literally must sits onto the battery box tray which is welded to the car...
22-02-2012, 10:26 PM
Everything that sits under the battery can be unbolted! Have you changed your gearbox mount?
22-02-2012, 10:27 PM
Foxy-jim Wrote:Everything that sits under the battery can be unbolted! Have you changed your gearbox mount? Errr yes...that's why I told him how to do it........
22-02-2012, 10:30 PM
Fair enough. I don't know then. The two bolts were under the mounting plate and not easily visible.
23-02-2012, 06:38 PM
I will confirm that on any 306 that ive looked at the bracket that holds the box mount could be unbolted from the chassis leg and was not welded.
04-03-2012, 06:54 AM
Neil Wrote:The bracket that it bolts to is welded to the body on the XU.They are on the DT too, Found out the hard way when one of the threads on the Bracket cross threaded & had to drill a new hole in the bracket & mount to secure it ! ...
On the 306 waiting list.
Gearbox Mount | Mighty306 | 5 | 3,230 |
10-04-2018, 09:45 AM Last Post: Mighty306 |
