A question about turbo noises.
Mine does the same whoosh sound. Standard kkk at 28psi defiltered it's awesome
http://www.youtube.com/watch?v=CbOXPFN0m1Y
You can hear the beginnings of it there... Just slightly raising the revs on idle would do it...
And yes, that's what happens with you feed the engine 22psi of boost at about 1800rpm and fuel it enough for 310+lb.ft... That's pure exhaust gas in the coolant.
#33
That is the noise i crave <3
starting to shit it a bit now, with ruans video, then again I don't think a gt2052 would make boost as fast as a vnt.
#35
Wastegate is a must for those sounds Big Grin
Although I run with a sealed wg and big airbox....
Then again with nowhere for the air to go it'll make those sounds anyway
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
#36
Ruan...
Im not sure what you are trying to show us?
The result of a HG blow when you push a blower too hard low down on a xud?
Or are you saying the sound is the coolant in my video?!
My coolant isnt pressurising and is clean...no funny smells etc!
(22-12-2013, 04:30 PM)Piggy Wrote: Ruan...
Showing the sound it makes you numpty, ignore the bubbling coolant!
The coolant frothing is just a slightly unwanted addition to the situation.
#39
Ahhhhhhhhhh
Yeah mine makes that noise too at idle...have to do another video!
Yes you do, go now, ride until night fall!
  Kkk turbo question Saloon306 1 2,126 10-06-2016, 02:22 AM
Last Post: bashbarnard
  Turbo question carlukepeugeot 2 2,551 03-06-2016, 10:19 PM
Last Post: carlukepeugeot
  Noises from under the bonnet knocking/rattling? Potta_91 7 4,705 29-05-2013, 01:25 PM
Last Post: doogle-d turbo
