Door loom plug
Could someone tell me if the ph1 door loom plug is the same as ph2 or 3? Could I fit a ph2 or 3 door straight on with out changing loom? Except doorcard and window switches?
Thanks Smile
 Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
you can use any plug as long as it has right the right pins, or even more.
Just make sure you know which wire is going where (continuity tester) and change one at a time.
Ballache of a job, good luck
Wink Door Loom Swapped - Central Locking Fault! partybish 8 6,622 29-09-2017, 08:58 PM
Last Post: paulgtt
  drivers door loom wires pug306driver 3 3,376 27-11-2016, 06:29 PM
Last Post: BiG K
  driver side door loom callumh121 2 3,071 20-01-2016, 03:40 PM
Last Post: callumh121
