Another Clarion pu2294a(c) thread
Hi all,
So after my girlfriends car getting broken into and her sub and amp getting stolen I am going to mount some small subs in the rear quarters, install a hidden amp to power them and swap the Alpine headunit for the standard CD player.
Now, my question is this on the C ISO plug is there an pre amp output? The ISO standard says there should be, if there is I'm thinking of using that for the amp if not I will have to use the high level input on the amp.
Does anyone know of a wiring diagram for the pins on the back of the headunit, I've been looking on google but couldn't find much.
MAYBE!
c1
pin1 out LR
pin2 out RR
pin3 ground
pin4 out LF
pin5 out RF
pin6 +12v amp sw
Yep, that's what I've found. I will have to do some measuring with an oscilloscope.
Haha, 5v pre out! I wish, that would be awesome if that was right.
Any idea what size connectors you need to go on to the pins there?
or
or
.pdf   rd3pinout.pdf (Size: 57.96 KB / Downloads: 210)
Wow, you can get a plug and cable already made up! £9 though, I'll find out if there is any output first before going any further.
http://www.ebay.co.uk/itm/Becker-Mini-IS...3a68508952
http://www.ebay.co.uk/itm/CT29AX03-Yello...231712318c
Bugger, not what I was hoping. It looks like there is no pre-out on these headunits. There is 5v on pins 1 and 2, there is also 10v on pin 4 but no signals on any of the pins.
Looks like I'll be using the high level input on the amp.
Thanks for your help Cully.
  Clarion Headunit Hacking Eeyore 8 9,267 02-05-2016, 08:26 AM
Last Post: Niall
  Clarion pu2294a(c) aux hack Mac5004 27 20,959 09-12-2013, 01:03 PM
Last Post: Mac5004
