Coolant change + cambelt help
be the first HDi I would have ever seen leak there...
you sure its not from higher up?!
Lol fair enough, as said i understand where you're coming from, but it's not like it's a regular issue. If we were talking about replacing p-bushes while doing balljoints it'd be a different matter, but throwing £50 at something that doesn't need fixing and isn't likely to either is daft imo.
and if you have never done it before, you could easily damage the seal or not fit it correctly and cause a leak where you didnt have one....
if anything is worth doing while the cambelt is off, its the water pump
  Noisy Engine After Cambelt Change tigerstyle 13 16,855 18-02-2017, 07:12 PM
Last Post: toseland
  Cambelt Change mspdan 14 7,176 23-04-2014, 12:07 PM
Last Post: Slam Wagon
  Engine Management Light after Cambelt Change Alan_M 6 4,624 05-03-2014, 08:01 PM
