Vibration
Vibration
Hi,
Just started to noticed a vibration coming through the car on the motorway around the 70mph mark.
It's not like a unbalanced wheel but almost like a rough bearing vibration.
I jacked the car up when I got home and tried spinning all the wheels and they all spin nice and smooth. There isn't the typical wheel bearing noise either but on the on the slip road turning left the was a bit of a grindy noise could this be coming from the off side CV joint, could it be worn, if so how could I check?
When I did the clutch the other month I checked the bearing that goes in the engine mount bracket and that seemed ok at the time.
Just thought I'd ask you guys your thoughts on this?
warped disc perhaps?
I'm not getting any vibrations through the steering wheel under braking. When I've had warped discs in the past the steering wheel and car has shook under braking but not getting any of that.
I've got a dial gauge and I'll check the runout on the discs just in case.
to check if it is a bearing lift the front wheels off the floor (make sure the car is secure) then start it up, put into 1st gear and build up a bit of speed then quickly switch off engine so you can hear any grinding noises coming from the spinning wheels, if its a collapsed bearing or driveshaft issue you should be able to hear it
cv joint...either inner or outer
wrong tyre pressures too can do this
Car on the ground reach under and try and twist the shaft, if theres play the cv has nearly exploded :p
I've not been able to do much but I did try to twisting the shaft and there doesn't seem to be any play there. Just thought should I try twisting with some lock on the wheel?
I've still to try the spinning up the wheels with the engine.
(24-04-2013, 09:18 PM)DeeTurbo Wrote: I've not been able to do much but I did try to twisting the shaft and there doesn't seem to be any play there. Just thought should I try twisting with some lock on the wheel?
DeeTurbo, what was the outcome, how did you solve this vibration issue? I have more or less the same symptoms.
Haha, well it turned out to be the exhaust not hanging right and the grinding type noise was coming from the CV joint.
But on the way home tonight I've noticed I've noticed there's another vibration again. Going to check the exhaust again but the vibration isn't like before.
Well it's turned out to be the engine mount, the new mount I fitted in the spring.
[Image: IMG_20131207_111856_zpsz6cupvx1.jpg]
Bloody shitty ECP parts.
Pug one on order now.
  Nasty vibration coming from the rear brakes johnny625 9 7,022 12-04-2020, 10:26 AM
Last Post: johnny625
  Strange vibration. decjhawes 12 5,689 21-04-2017, 05:22 AM
Last Post: Poodle
  VIBRATION- balancing and tracking done thealphanoob 0 1,666 22-04-2015, 10:13 AM
Last Post: thealphanoob
