Threads: 102
9
id try and keep the gauges fitted oem style. my rover has them hidden, next the gear linkage. no radio in the car so I have the blanked off with an OEM pov spec radio blank. so the car looks dead basic from a glance.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
A boost gauge only tells half the story on these turbos.
It's really quite crucial to monitor emps on a vnt when controlled in such a none oem way.
Shagged my first vnt which should have been in great condition after I rebuilt it, despite knowing exactly what emp it was running (too high :p)
Nice to see the engine out again, many people would agree its the proper way to do things
Threads: 226
24
Car Model/Spec: A3 TDi
I like your steering wheel.
Threads: 591
54
Looking good chap...keep at it
Threads: 19
12
(23-10-2013, 08:39 PM)procta Wrote: id try and keep the gauges fitted oem style. my rover has them hidden, next the gear linkage. no radio in the car so I have the blanked off with an OEM pov spec radio blank. so the car looks dead basic from a glance.
I'm trying, bit hard when I'm potentially going to have 7 gauges to fit.
(23-10-2013, 08:52 PM)zx_volcane Wrote: A boost gauge only tells half the story on these turbos.
Wasn't too bad to drop the engine really, reckon hour and a half if I hadn't of got distracted. No shaft play on the turbo which is good, if I do ever blow the turbo I won't be replacing with a VNT unless I spy a bargain. So hopefully keep it going a bit longer. I know I should of had the gauges installed in the first place but couldn't afford it and I was pushed for time. Still, don't think I have hurt anything. I'm not really a hard driver.
(23-10-2013, 10:45 PM)Tom Wrote: I like your steering wheel.
Basic of the basic in the 206. It's alright. I'd like a suede one but I like OEM too much.
(24-10-2013, 06:16 AM)Piggy Wrote: Looking good chap...keep at it
Getting there...hopefully be worth it for the sound it'll 'hopefully' make. (and I don't mean the bang when (not if) the block throws a leg) You have to remember the block is a completely stock D8A with real unknown history with only win studs holding the head to the deck.
Threads: 19
12
Never actually updated this when the engine went back in.
Paddle Clutch Fitted
Painted up the exhaust with some B&Q special BBQ paint....its quiet good actually hasn't flaked off yet - did paint the whole system.
New Genuine pinch bolts and hub nuts (mine have had a hard time with the amount of times they've been removed)
Going back together
ready for front bumper all but
Cobbled together some fittings
Got my neighbour to machine this one down so I could get my 4mm pipe on.
Couple gauges in
Fitted a lairy rear box (was the only thing I had - though not as bad as carl's ;P ) but will sort a more subtle tip when I have 10 mins.
Frosty popped over and we attached the exhaust and finished off some bits and pieces, dropped the car down on its wheels and fired her up. Bled the coolant....which my homebrew coolant system seems to be able to do all by itself.
Went for a test run and all seemed to be well.
All the gauges worked, however the oil pressure one seems too fluctuate a minuscule amount (a bit like a 205 speedo effect) but still, it works. EGTs are average on a hard pull, reckon the exhaust helps with that. EMP seemed to be rather high, as in pinning a 60psi gauge high. Its just down to the turbo not fully coming on song until around 21psi which you then get an almighty surge in power (which yes, feels awesome but can't be good) and this makes the car quite laggy before then. Wound out the controller and its about 19psi now.
Maybe a bit too much fuel
Trouble is at the moment is that to maintain lower EMP you need to keep load on the turbo to get pressure up to 19psi, but is rather hard when cruising on the dual carriageway. So I have some thoughts but just need to have a play at some-point.
Weekends is the only time really I get to play on the car but seeing as I've been doing that for the last few months I've thought I'd do something different.
Still engine and diesel related but more agri spec.
On Sunday, Frosty popped round and helped bolt my spare (originally first fitted one to the 206) engine up to a stand I've borrowed
So that's ready for a strip down now.
Threads: 266
18
Car Model/Spec: 205 DTurbo
Nice update. Sounds like the VNT is being a bit of a pain in the ass, not filling me with confidence tbh!
Threads: 19
12
(19-11-2013, 12:24 PM)silverzx Wrote: Nice update. Sounds like the VNT is being a bit of a pain in the ass, not filling me with confidence tbh!
It is and it isn't I knew it wouldn't be easy but it's coming together. It is worth it for that exhaust roar  and the lack of effort needed for a speedy pull off.
Having a sort of thought running round the old brain box for something RWD running an XUD setup
Threads: 90
54
That pin for the engine stand to stop it turning is on the floor in my workshop Mark, Chris found it shortly after i left must have dropped out lol. Glad to see a head bolt being used for substitute lol.
Threads: 19
12
(19-11-2013, 12:53 PM)darrenjlobb Wrote: That pin for the engine stand to stop it turning is on the floor in my workshop Mark, Chris found it shortly after i left must have dropped out lol. Glad to see a head bolt being used for substitute lol.
haha yeah, perfect fit!
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Yes another update even though I know pretty much everything that is going on with this though the turbo side of things does confuse me lol
Threads: 127
33
Pinning 60psi emp is rather troubling :O
Threads: 117
119
Love that fmic install, so very tidy. Is that a typo or has someone sold that to you as a paddle clutch..? Because, well, it's not lol...
Threads: 122
9
Car Model/Spec: Kingfisher Ph1 Dturbo S
Sure looks like a paddle clutch to me
*confused*
Threads: 90
54
(19-11-2013, 04:20 PM)Poodle Wrote: Love that fmic install, so very tidy. Is that a typo or has someone sold that to you as a paddle clutch..? Because, well, it's not lol...
Thats 100% deffo a paddle clutch lol...
Threads: 110
20
Going to explain any further? I got marks and my paddle clutch from CG. 4 paddle unsprung friction plate. We're both using standard valeo pressure plate and bearing
Threads: 117
119
Total facepalm, my mobile only showed me the left half of the picture. So yeah, that absolutely is a paddle clutch and i have my coat on, my bad!
Threads: 110
20
(19-11-2013, 06:03 PM)Poodle Wrote: Total facepalm, my mobile only showed me the left half of the picture. So yeah, that absolutely is a paddle clutch and i have my coat on, my bad!
Lol
Threads: 129
11
Oh poodle I was just about to comment!
Great project this, that clutch is what I had on the 205 and will be fitting to the Sedan, once they bed it they grip like f*ck! And having no springs isn't really that bad in all fairness.
Stage 2 XUD Sedan
Threads: 42
2
Car Model/Spec: 1.9 XUD
(19-11-2013, 11:33 AM)mr_fish Wrote: Fitted a lairy rear box (was the only thing I had - though not as bad as carl's ;P ) but will sort a more subtle tip when I have 10 mins.
Screw you dude!!
For that comment I hope you never figure out VNT control and you get so stressed you lose all your hair
Great progress, would love to be taken out for a drive at some time in this.....
Threads: 19
12
20-11-2013, 10:07 AM
(This post was last modified: 20-11-2013, 10:11 AM by mr_fish.)
(19-11-2013, 03:04 PM)zx_volcane Wrote: Pinning 60psi emp is rather troubling :O
Don't worry I'm on the case  she'll be reet though (hopefully  )
(19-11-2013, 06:26 PM)strictly_perv Wrote: Oh poodle I was just about to comment!
Cheers, done a few miles with the clutch now, including town driving...when warm - brilliant, when cold - quite snappy I find but seems to be ok.
(19-11-2013, 11:13 PM)c.gerrard Wrote: (19-11-2013, 11:33 AM)mr_fish Wrote: Fitted a lairy rear box (was the only thing I had - though not as bad as carl's ;P ) but will sort a more subtle tip when I have 10 mins.
Screw you dude!!
did I say bad? I meant....'as free flowing as carl's'
Latest issue with the car (not turbo related for once), the alternator seems to have flicked me the 'v' sign and quit it's job.
Threads: 266
18
How have you plumbed your EMP probe/gauge in? Ruan's told me they aren't the easiest thing to keep secured.
Threads: 19
12
(20-11-2013, 10:54 AM)silverzx Wrote: How have you plumbed your EMP probe/gauge in? Ruan's told me they aren't the easiest thing to keep secured.
Tis a thing of beauty and a complete lashup (naturally), people think I have a brake line running over my engine. Unfortunately it doesn't look like I have any photos. Will see if I can get some tonight.
Drilled and tapped the manifold, screwed a fitting in, flared a length of copper brake line and clamped that to the fitting. Ran that up to the top of the inlet manifold, slid another brake fitting on, flared the end of the copper, screwed into a brass fitting that changes the pipe to the small nylon type. Run that inside the car up to the dash and connected it to a random gauge I found.
as said, a bit of a bodge, but its secure enough, was nigh on FOC to do (which is always good), and works fine.
Threads: 266
18
(20-11-2013, 11:49 AM)mr_fish Wrote: (20-11-2013, 10:54 AM)silverzx Wrote: How have you plumbed your EMP probe/gauge in? Ruan's told me they aren't the easiest thing to keep secured.
He did mention using copper line as it's pretty impossible to blow/destroy from preassure alone!
I'll have to look into that then, perhaps you could PM / post some pictures up at some point!
Threads: 19
12
Quick pull away clip from ages ago when the derv crew were round and after dropping the exhaust.
Cheers to Frosty for whipping his phone out in time.
Threads: 110
20
Im sure I have seen this video somewhere before lol
Threads: 226
24
I want a turbo that makes epic win noises like that!
Threads: 35
7
Car Model/Spec: Phase 1 dturbo sima blue
Just been out for a drive In this thing and it shifts the noise for the vnt is epic good fun
Threads: 102
9
(28-11-2013, 10:07 PM)mikey b Wrote: Just been out for a drive In this thing and it shifts the noise for the vnt is epic good fun
I am not surprised, as its a small car with a wound up engine in.
Threads: 19
12
Nothing much changed really, car is being used daily as my HDi is being worked on. Surprisingly it is behaving at the moment though with all the abuse its getting. I do like driving it but the spool of the turbo and drone of the exhaust is a bit monotonous.
- VNT control is working as well as it's allowed so far
- Changed the Nimrods for some 15" steels which ought to of been painted but wasn't really fussed at the time.
- Clutch has bedded in nicely, only a faint shudder when pulling away when cold but apart from that it's quite alright to drive
- Latest change being the exhaust was a bit 'in your face' and I'm really an OEM+ fan so (with help from another radger) we lashed up a downturn out of some old lorry exhaust.
Anyways, updates are useless without a couple of pictures.
Quick picture from when I went and got fuel the other night, car is hanging really but I leave for work in the dark and return home in the dark so lack of enthusiasm to wash it.
One of the tip lashed up....spy the 11mm coal hanging off the back...
and the next project...been left out for a couple years, quite the relic but FOC so was worth a go....and yes it does run to a fashion now.
Cheers for Looking
