Threads: 80
10
I'm still having some issues with jolty throttle when coming on/off the throttle no matter how delicate I am as well as some typical stalling issues when revs are dropping to idle.
After a lot of reading online it seems that this issue could be caused by the throttle plate closing too much (some vehicles require a very slightly open throttle all the time to relieve the icv of all the work).
There is a screw on the throttle body which allows you to adjust the closed position of the butterfly, I was wondering if anyone knew what this should be set at or if there were any servicing guides in autodata?
thanks in advance
Lewis
![[Image: sigjpg.jpg]](http://i44.photobucket.com/albums/f32/cassandra--gemini/sigjpg.jpg)
Serious.
Threads: 42
28
there is no adjuistment possible without modification, likely to he an ICV or TPS failt.
coupled with a worn out engine mounting, or cracked cradle.
Threads: 177
3
Why not pull the cap off and have a look?
Threads: 42
28
it will not and should not ever need adjusting from factory setting, you have a fault elsewhere.
the swampy earth leads make me laugh.
Threads: 42
28
I'm not sure what the voltage should be specifically, but given it is not adjustable they all should be the same, the screw is there for setting in the factory.
IAT is unlikely its just a temp sensor which doesn't vary the fuelling much, quite different to the green CTS
map tps and icv faults are very common, as are wiring faults now too as they are getting on.
Threads: 80
10
Well, unplugged the TPS and drove to work and the on/off throttle jerkiness is much better and the large amounts of engine breaking has also disappeared.
As the sensor is new I'll be checking:
- supply voltage
- signal voltage change
- earths
Continuity back to ECU pins
Anything else?
Also this sounds like a really stupid question, but to remove the loom to the ECU do you literally just pull the silver clip up and pull hard?
Serious.
Threads: 581
195
Careful testing back to the ECU without knowing what sort of signals/voltages the may send or receive. You could do damage!
Threads: 58
3
Car Model/Spec: Loads
Given 9 thank(s) in 9 post(s)
The TPS can fill up with oil etc causing issue's, or check the ECU loom earthing as I guess with adding extra is covering a issue, All the ECU sensors goto the ECU and not ground so adding extra earths will do nothing at all
