Rear compensator ph1 s16 urgent
Evening all after the above for my old s16 must be free ɑnd not leaking! What ya got??????
[Image: SDC10442-1.jpg]
What's peoples thoughts on bypassing this??
Considering ιts a track car with gti fronts, ιts not as if the rear ιs ever going to have load! Does ιt need a load compensator??
(05-11-2013, 10:23 AM)Jonny b Wrote: What's peoples thoughts on bypassing this??
Probably be surprised with the effects that has.. I'd probably go for the fixing it option.
On the 306 waiting list.
this ^^^^ i wouldn't do it again lol
How are the s16 valves any different to any other phase 1?
(05-11-2013, 01:06 PM)ginge191 Wrote: How are the s16 valves any different to any other phase 1?
I think all the compensator valve are the same on ph1s and maybe all the 306s. Im not sure if disc and drum axles maybe different though
The axle on my d turbo doesn't have a compensator valve but my S16 does. Im not sure why some axles do have the valves and others dont
Well iv had ph3 gti axels on ph2 without the compensater and it was fine.
Frost, ph3 beams dont have then as the load is compensated by the ABS system instead, hence why some axels dont have it
Sad rear brake compensator hycraig 0 2,313 26-03-2019, 07:57 PM
Last Post: hycraig
  Wanted: Brake compensator bits. Jonny81191 12 5,251 17-09-2015, 07:55 PM
Last Post: Jonny81191
  Wanted: URGENT! Rear pads and brake line Nathan1305 8 4,639 01-09-2014, 06:17 PM
Last Post: Nathan1305
