30-60mph in 3rd times??
Checked out some stats...
a Golf R32 does 30-70 in 5.9...
happy days Big Grin
Thats petrol shite tho bud get that boost up Smile iv still not found my fault but impressed with my times even down on power roll on compo payout big blower remap, uprated clutch and 300 bhp once I get sorted and get to rs tuning haha
[Image: J5hxCcC.jpg]
Why I'm putting this on here I have no idea
A gti shouldn't be made to do this in 3rd gear, it's not fair, but here it is!
On my private runway of course!
Are you supposed to do it in one gear (3rd in XUD case)?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(02-11-2013, 03:40 PM)silverzx Wrote: Are you supposed to do it in one gear (3rd in XUD case)?
That's how most people do it, however it makes for a terrible time in a '6!
What sort of times where people getting in there standard d turbos ?
30-70 run kind of.
http://www.youtube.com/watch?v=y17AjJBPB...e=youtu.be
I just had a mate stop watch mine out of curiosity, timed 6.1 seconds, that running a lucas, which needs more fiddling, and t2 at 17 psi on a top mount cooler with a straight through zorst Smile
(21-04-2014, 01:14 AM)philpemberton94 Wrote: I just had a mate stop watch mine out of curiosity, timed 6.1 seconds, that running a lucas, which needs more fiddling, and t2 at 17 psi on a top mount cooler with a straight through zorst Smile
Im not saying you're lying but I would be very surprised if that time is accurate!
Thats just what he timed it at, may be a bit more, so i will have another look later! it is a pokey little car though, spins up in second in the dry....
No smoke, No poke!
To be brutal, 17psi is only just above stock psi, and with a lucas, I would think its more like 9.1seconds unless you have stripped it bare?!
Be lucky if its under 10 seconds tbh...
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
No not stripped out! But like i said thats what he timed it at, so ill try again with someone else timing it haha, its definitely not 10 seconds though! Smile
I dont think anyone has cracked 130bhp on a lucas and those who were close were almost certainly running more psi. So as much as you think its "pokey" drive one with a modded bosch and a bigger turbo you'll never want a standard turbo again
[Image: av5ym8.jpg]
i had my lucas tuned to 20psi, never timed a 30 to 70 run, but certainley wasnt under 8 - 9 seconds, well downhill maybe Wink
http://youtu.be/L95cyUVDABA
Bosch pump screwed,
Lda washer removed and turned to steeper side,
Ko3 turbo standard
Tmic
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
I make that 8seconds. not bad really....esp as its arse is draggin Tongue
(22-04-2014, 09:19 PM)Piggy Wrote: I make that 8seconds. not bad really....esp as its arse is draggin Tongue
Yeah stopwatched it a few times its around 7.5 to 8.
Arse is draggin a bit alryt, in the middle of rebuilding another axle, when that goes on ill rise it up 10-20mm. Smile
When i get my 2.5 inch straight pipe on would you say that time will drop a bit?
not really, it should spool a little more mind...a little ko3 aint really going to see much improvement...2.5inch is crying for a bigger blower
Ah at least it'l sound good with it anyway Smile
  50-80 acceleration times. daveylennon93 17 11,227 17-07-2014, 08:59 AM
Last Post: kelvsere
  Sad Times Are Sad c.gerrard 15 8,421 30-11-2013, 08:51 AM
Last Post: darrenjlobb
  probably been asked a million times before... LewisG306 3 3,320 04-10-2013, 03:01 PM
Last Post: Piggy
