boost guage
boost guage
anyone know where to route the boost gauge through the bulk head without drilling a hole planning on having it in the drivers side vent ??
Look underneath the master cylinder on the right hand side, tucked away near the top of the bulkhead is a rubber grommet.....push a screwdriver through first then thread the hose through, it'll come out in the driver's footwell. All you need to do then is route it to the vent and cable tie it neatly under the bonnet. Don't forget to put a slim line rollie filter in the pipe to stop the gauge fluttering.
gareth7 Wrote:Look underneath the master cylinder on the right hand side, tucked away near the top of the bulkhead is a rubber grommet.....push a screwdriver through first then thread the hose through, it'll come out in the driver's footwell. All you need to do then is route it to the vent and cable tie it neatly under the bonnet. Don't forget to put a slim line rollie filter in the pipe to stop the gauge fluttering.
is that the same on the hdi?
only one i found comes out behind the dash, nearside, and the other one is passenger footwell and then go behind the centre console and go up to the vents? i havent done it yet ive only looked over to see where was best to go..
also the filter, i done a search for that and dident find anything, put it in google and even that come up with weird results.. sooo do you mean this?
http://www.ebay.co.uk/itm/Line-Filter-E ... 011wt_1139
so would people recomend these? or not worth it?
Slim line rollie filter = cigarette filter
Has anyone got a photo of the bung cheers
Yeah joe it's the same on the HDi, that's where i have mine routed too and it comes out to my gauge in the drivers side vent. Bung is right next to the mastercylinder mate, with a long screwdriver you can poke through it
is it the bung with the two hoses coming out of it to the right of the master cylinder ??
Shouldn't be anything coming out of it mate, you've got the wrong one.....look underneath the MC on the right hand side, it's quite high up on the bulkhead and just above the servo. If I get chance later I'll get a photo up.
cheers a photo would be great dont want to go poking a hole into something important
any one got a photo of what bung they routed the pipe through ???
sorry mate, forgot to get that photo up for you.....you seriously can't miss it though, look at the top left hand side of the bulkhead where the master cylinder connects to the servo then look to the right hand side of the servo right up underneath almost where it meets the scuttle panel and you'll see a rubber bung about 20-25mm diameter in the bulkhead......this is the one you want and it's the only one there.
I could do with a photo of this grommet too, my boost gauge hose runs round the door seal at the moment, and i wanna get it put in properly asap. Big Grin
I'll get one sorted later today when I get home from work
tried to get one but my camera's too big to get in close and trying to zoom in on it just isn't happening.......follow my description of where it is in my earlier post.....you can't miss it if you head is level with the top of the engine
Guess I'll properly sort mine and wire it in one day lol
[Image: siggy1.jpg]
Just had a look, and ive found the grommet you mean! Result. Thanks for that mate, now i can reroute my boost hose and stop crushing it in the door! Big Grin
devils_fuel Wrote:Guess I'll properly sort mine and wire it in one day lol
Theres an earth in the footwell and you can tap into your headunits ignition live.. 15minutes work Wink Get on!
I used both the live AND ground for the headunit, works fine for me! Big Grin
WiNgNuTz Wrote:Just had a look, and ive found the grommet you mean! Result. Thanks for that mate, now i can reroute my boost hose and stop crushing it in the door! Big Grin
No worries mate, easy to find when you know where to look lol
Could I get a picture of this anyway?
Also does this bung apply to phase 1's ?
