Guide; Mid box to back box conversion
doesn't it leak from where you've drilled for the threaded bar to go through?
Nah I used a few fiber washers wither side
I feel i should point out he doesn't actually know this, what with never having kept a car long enough to have to MOT it... Wink
Gonna try this one in the near future, when my mid-section is going to get replaced.
I've just done this conversion earlier today.
I used an old exhaust clamp and put the threaded bar through it, with nuts and washers, like so...
[Image: QzVpdrN.jpg]
[Image: UcNzEeh.jpg]
I also decided to stick a shiny exhaust tip on it. Big Grin
[Image: q09WIJb.jpg]
[Image: MIRKxNP.jpg]
(22-09-2013, 02:44 PM)me-tm Wrote: I've just done this conversion earlier today.
Thanks for that, I fitted mine using exactly this method last night in the dark, took half an hour.
Sounds crazy now being straight through from the turbo!
Iv welded in a centre box from a yaris. Shaped like a cherry bomb silencer, looks to have great flow inside and has quietened it down low down the revs like i wanted. Wasnt to sure were to fit it though so i welded it where my back box should be. Anyone know if the positioning of silencers makes any differance? I should imagine you would need it furthest away from turbo right?
brilliant - have decat pipe & hopefully have a crack at the weekend - thanks for the guide!
Current - 306 ph1 xrdt - 323 estoril. History - Legacy Outback - Impreza Wagon - BMW 530 - Golf GTI mk2 - Escort TD - Audi 80 coupe - Astra GTE - Escort XR3
Project : http://306oc.co.uk/forum/thread-23625.html
(27-10-2013, 07:00 AM)JJtheHITMAN Wrote: Iv welded in a centre box from a yaris. Shaped like a cherry bomb silencer, looks to have great flow inside and has quietened it down low down the revs like i wanted. Wasnt to sure were to fit it though so i welded it where my back box should be. Anyone know if the positioning of silencers makes any differance? I should imagine you would need it furthest away from turbo right?
as far as i know each bend is supposed to change the note of your exhaust so would imagine it would
So my mid-back box mk4 on my estate.
Cut the hangary bit off the original back box and used that and a massive jubilee clip to secure the mid box to the car then clamped on the original down pointing tail pipe.
[Image: attachment.php?thumbnail=11049]
[Image: attachment.php?thumbnail=11050]
I'm not posting mine, it's that bad lol.
  Injector Pump Change Video Guide (Bosch Conversion) darrenjlobb 5 7,586 15-02-2013, 09:44 AM
Last Post: Face.
