	Threads: 6
Car Model/Spec: 1.9td Sedan
		Hey up,
Anyone ever had an issue with wet carpet in a Sedan boot and how to resolve the issue? Only thing I can think of is the Boot Seal but thought I'd ask jusy incase there was an alternative or other possible causes.
	Threads: 202
58
		Lots of wet biking kit and no way of the damp escaping??
	Threads: 202
58
		Ah, ok.. Just thought it was worth a check. I soaked my estate on several occasions with kayaking kit.
Check the rear lights aren't leaking into the car
	Threads: 6
		Saying that, My drivers rear lights were out few days ago, so I replaced the bulbs and discovered a small amount of water in the cluster. That's certainly something I'm going to check out in the morning.
	Threads: 4
		the cushion thing under the carpet in mine is damp but not carpet so i would like to know aswell, im putting it down to the hole in the floor for towbar wiring
	Threads: 252
7
		Mines always like a swimming pool. I can't figure it out tho. Cleaned back of lights and seals all good
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
	Threads: 141
35
		Sedans collect water in the recess around the boot lid, I guess if the drains are blocked it would find its way into the boot somehow.
My sedan was awful for leaking, water through the tops of the doors and the boot used to get filled up with coal haha
	Threads: 252
7
		I have cleaned it all out when I was refurbing stuff washed all backs or lights out, seals and treated the gutters that were rotten. But its still full
Sedan Project
Blaze 1.6 Dead
	Threads: 62
10
		Sounds like your boot seal then.  Try taking it off,  cleaning i,   treating it with something then refitting.  Could be rusty behind it.
HDi Owner for 200k/9 years
