Threads: 15
Car Model/Spec: moonstone 306 hdi
My car is making a humming noise whenever driving straight or round a right hand bend ... i had my wheel bearing replaced only a month and half ago but only rrplaced a broken droplink with new knew ones a few weeks ago and has been getting worse and worse ... i originally thought it was due to having a broken droplink and not rrplacing it but when ive jacked up the car the wheels sound silent :/ ... the only thing that makes it go away a bit is when going round a left hand bend or turning left.
Any ideas ???
Thanks.
Threads: 0
45
Cheap wheel bearing that has failed already?
Threads: 198
135
If it sounds like a wheel bearing.. its a wheel bearing.
Nothing to say it hasn't packed in again, I used a cheap one once that lasted literally weeks. Will be exaggerated especially if the guy who pressed it in did a shite job of it.
Threads: 39
Car Model/Spec: P2 Dturbo
i had this exact problem on the other side its the bearing
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Threads: 15
I know it sound like it but when the cars jacked up the wheels silent when driven so i dont think it is the bearing, any other ways of checking if its the bearing or not ? Thanks
Threads: 163
53
Car Model/Spec: 406 HDI
If a wheel bearing isn't pressed in exactly straight (like when I tried to do it with a hammer and a block of wood) it'll die in no time mate.
Probably the bearing as above. Could also be a noisy tyre though, easy to check by swapping the wheels for a test drive.
Threads: 39
theres no load when the cars jack up in the car on the wheel so might be a reason you cant hear it
Threads: 206
Car Model/Spec: 3dr dt-s
27-09-2013, 05:20 PM
(This post was last modified: 27-09-2013, 05:22 PM by daddyfixit.)
drive in a straight line till you hear the noise;
turn slightly left or right while its noisy----if noise goes turning one direction, its the other side gone....in other words as a load is put on to one side by cornering it will be noisier.
just read op-----its the left bearing thats noisy----as you turn right.
Threads: 70
10
Car Model/Spec: HDi Estate
Given 9 thank(s) in 9 post(s)
Exactly the same thing happening to mine at the moment, no need for a thread when all the info is in here!
Front bearing isn't easy to DIY with a press being needed then etc?
to be honest...its bloody difficult NOT to get it in straight!!!
if the bearing is good quality and the hub isnt buggered the tolerances are so tiny that it will just jamm solid if its not going in straight
Threads: 90
What normally happens is who ever does the job gets f*cked off / lets inside / outside of bearing split, and then grit / shit gets in there, this is what then goes on to f*ck the bearing..
Its pretty impossible to press it in on the piss..it will just pinch like f*ck if you do, it goes down and sits flush at the bottom when its fully in.
Threads: 11
Car Model/Spec: 306 1.6 Sold!!!!!
I smashed the one's old out and got a local garage to press them in for beer money.
Might be worth a try.
