Wanted: Auxiliary tensioners engine bracket
Sad
Anyone got the black cast bracket on the engine that the pas pump bolts to and houses the auxiliary tensioners / idlers
For a ph2 d turbo
Cheers
Team Doesn't own a 306
yes.
got a pic though as there a couple variations!
Thought they was all the same? What's the difference
different alternator mounts...as I found out
you need just bracket or tensioner/pulley too?
Need the tensioner and pulley but thought it would be easier tho change the lot for a known working part
this is what I got available...
[Image: 20130930_192148_zps01c4786b.jpg]
[Image: 20130930_192152_zpsd291fb13.jpg]
but there is a variation with a auto sprung tensioner and a cammed lower pulley tensioner which I am running.
dont think its that one mate, the one i need has a big spring tensioning it and dosent have the lower idler
thats an upper idler! lol!
mines got the bit spring bit, and a lower adjustable pulley
whats that threaded bar for?
manual adjust tensioner
  Wanted: Ph1 Tailgate Parts, Ph3 abs bracket Sambarker 2 2,880 01-02-2016, 11:09 PM
Last Post: Sambarker
  HDI lower engine mount/drive shaft bracket titch 4 3,635 03-03-2015, 11:57 AM
Last Post: titch
  Wanted: HDi Aux bracket and PAS pump WiNgNuTz 6 3,625 04-08-2014, 12:06 AM
Last Post: mspdan
