Guide: Fitting Plasma dial face's
cully Wrote:
Neil Wrote:Cully JUst Wondering why you wired it in to the headlight leveller?
the invertor that powers the dials wants 12v and the wires i picked up come on (12v) with the lights and dont dim with the panel dimer Wink
Ah fair enough!
#32
what wires have you connectedd them to?
#33
is it wired to the head light leveler?
#34
Mowle5677 Wrote:is it wired to the head light leveler?
mine is connected to the headlight leveler plug (ph3 Hdi)
Red wire = 12+ light feed
Green/yell =0v/ground
[Image: DSCF5799.jpg]
#35
i ripped my car apart till i found the part that looks like on here Smile
#36
hi 2 things were you get plasma dials from and that black box that shows mpg what is that and were you get that from as well thanks
#37
i bought the dials from ebay a user named "chromemanics" there web site is http://www.visual-performance.co.uk/#/306/4534291809
the black box is a scangauge II http://www.scangauge.com/
be warned it only works on the hdi not the petrol stuff Wink
#38
Good guide
ive just bought some from member... they fail to light up. Is there something im missing... theyve been bench tested all the contacts look fine.
S2 HDi >click<
154bhp
280lbs/ft
#39
did you also get the invertor box and the switch and brightnes adjuster that powers the dials?
all the black dial plugs plug into it
#40
I did the kit looks just like yours. The switch is on and ive had a looks over the joins and connections visually. They seem fine but ive noticed the wire is thin.
S2 HDi >click<
154bhp
280lbs/ft
#41
A contact had snapped.
its worth getting some ph2 needles or colouring the ph3 ones red with a waterproof felt tip. Does make a difference and the red glows through when the lights are on
brilliant guide by the way
S2 HDi >click<
154bhp
280lbs/ft
#42
Not a fan of plasma's, sorry, they just don't do it for me..
#43
Dont fit any to your car then Smile
Just for you doddy!!
Theres better kits out there for more money. Xtuners will make you a oem style set. There was a group buy... however not cheap. These are definately better than the standard dials imo ofc
S2 HDi >click<
154bhp
280lbs/ft
#45
Mine are Xtuners ones and i love them! Not exactly OEM but not as bright and as in your face as the cheaper ones we did a group buy on.
[Image: IMG_1069_zpsd2a53ae1.jpg]
#46
*faces
[Image: sigcopy-1.jpg]
#47
the xtuners ones are gorgeous
where can I get some ph1 diesel dials from? can only find ph2/hdi ones
#49
xtuners pal.... Wont be cheap but you'll get some sweet looking dials fo sure
S2 HDi >click<
154bhp
280lbs/ft
  Guide: Lynx Rotrex SuperCharger Fitting Guide Eeyore 0 3,039 18-03-2016, 11:34 AM
  Guide; GTi6 Spliter Fitting Dum-Dum 4 8,351 08-06-2015, 04:34 PM
Last Post: woody90
  GUIDE: Fitting Upper & Lower Strut Braces Eeyore 39 46,959 29-03-2015, 01:42 PM
Last Post: Rippthrough
