Bosch
Bosch
Finally getting my bosch pump fitted today (9mm gov mod lda grind) Interested to see the diff between Bosch and Lucas.....
I also have a td04 waiting but ill see what I can do with the T2 1st. Any recommended boost level not to exceed. I don't want to kill it.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
I ran my t2 at 24 psi for months. Had no shaft play whatsoever when it was removed
HDi Cabby Project Click
I've just done a lucas to bosch change and its far far nicer top drive, doesn't feel so flat.
25psi is a safe enough pressure, but sticking a TD04 on is never safe if I'm honest unless you run it low boost but then theres no point having it over a stock turbo.
Stage 2 XUD Sedan
Oh. The geezer just let me know he can't come today. Ffs! I was looking forward to that.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Mines ran 30+psi for over a year (usually around 34)
Then its now leaking to 26-27
However I wouldn't reccomend it! Aparently safe is around 22 but pushing it to 24 should be ok
Prob head for 25ish then pop the td04 on if I get bored. :-)
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Ive had a k14 and t2 both run at 22-24psi for loooooooong time.
the k14 lasted like that for years till it started to whistle. but even then it kept going
