Setting a stock idle on a modded pump!?
(18-09-2013, 06:52 AM)Piggy Wrote: I have my scouts at kidderminster, swindon, minehead and brighton. inc my home town of stow...
all at a quid a litre in those stores?!!
PS whats JJs?!
jj foods . .Smile
#32
have to google my nearest place...im in middle of nowhere. has it benefits but not when you want to buy something!
(18-09-2013, 07:50 AM)Piggy Wrote: have to google my nearest place...im in middle of nowhere. has it benefits but not when you want to buy something!
yeah there's about 5-6 of them iirc . . . .my nearest is like 8 miles away=winning . .Smile
#34
PS whats JJs?!
jj foods . .Smile
http://www.jjfoodservice.com/product.cfm...20L/OIL068
seems good; 94ppl
theres one in bristol...I pass that way every 6wks to see family
what do you have to do to join? need a company name etc?!
PS whats JJs?!
jj foods . .Smile
seems good; 94ppl
yep that's what i'm using atm . .can get veg even cheaper . . . http://www.jjfoodservice.com/product.cfm...20L/OIL072
#37
(17-09-2013, 08:22 PM)Piggy Wrote: rapeseed is very easy to get hold of.
tesco have it on offer every other month or so for a quid a litre in 5litre containers.
They don't have it in my Tesco. Well they have but it's 3 quid for 2 litres which doesn't make sense. Nearest Costco is 70 miles away. Unless you are "in the know" it's harder to get hold of than you think.
#38
(18-09-2013, 07:44 AM)Mattcheese31 Wrote: jj foods . .Smile
seems good; 94ppl
yeah but thats soya...shockingly bad
no mate...its called common sense.
I dont have anyone "in the know"...I just google/ebay and LOOK
the soya ain't great, but u just need to mix a little petrol in Piggy.....
#40
as people have shown with their own experiences its not worth the few pence per litre in saving with soya. it starts/runs bad even with a mix and flat spots are worse.
just not worth it imo.
(18-09-2013, 05:48 PM)Piggy Wrote: as people have shown with their own experiences its not worth the few pence per litre in saving with soya. it starts/runs bad even with a mix and flat spots are worse.
i've been running SVO for three years now, i'm not saying it's great but how long have you been using it again? . .Smile
#42
about 6yrs.
half of that experimenting with making my own fuel with waste oils etc. but often when a supplier runs dry, I head to SVO as my backup. Having to do that even more since moved as havnt been able to get a good wvo supplier Sad
(18-09-2013, 05:55 PM)Piggy Wrote: about 6yrs.
well fair enough then, but it's only the viscosity that fcuks you and petrol thins it out just fine, i am saying all this and i'm running ra*e atm though . .lol
#44
mmmmm
#45
its not just viscosity.
thats a tiny part of the issue really. Baring in mind that once its warm most of that viscosity difference at room temperature evens out
(18-09-2013, 07:57 PM)Piggy Wrote: its not just viscosity.
then pray tell what is it then Piggyfeatures? Smile
#47
theres more to it than I ever realise but do some googling on energy values in soya oil compared to rapeseed and be prepared to get bored real quick!!
Went to Tesco again on Wednesday, no sunflower and just two bottles of veg. Whoever said it was easy to get hold of needs to be shotTongue
#49
Costco, always at least 2 pallets on the shop floor Wink
#50
My tesco always has loads. I've stopped using it though after moving to the 10mm pump, feels so flat to drive i actually rather despise it. Diesel ftw. Will throw veg in if i'm doing any long journeys but I avoid it like the plague, especially as I needed a full seal rebuild of my pump after running 100% SVO for 6 months, was pissing fuel out everywhere.
Bear in mind refined diesel contains detergents too that help stop your engine from clogging up with shite. Veg is nasty sticky stuff if it's heated up and then left to sit, I think that was my problem as the car doesn't get driven often and pure veg would just rot stuff away from the inside out when it wasn't being used.
Even when warmed up though it feels lifeless at 3krpm up, almost like a boost leak with the sudden loss of power. f*ck, i want bigger fuel lines for running diesel, never mind the gloopy veg.
#51
Im now running 60% veg. probably will only ever go to 75%.
for those reasons
I'm avoiding it as best I can. Unless i need major economy I don't see any point restricting a higher flowing pump with that stuff. Just makes all the effort pointless.
#53
Even on my 9mm Bosch I'm considering whether it's worth it. When I was in Cornwall I couldn't find any cheap veg so had to run diesel and it was like having a bigger blower, felt no different off boost but went like a rocket on boost, the pump just can't keep up with the demand for fuel on boost.
#54
(27-09-2013, 11:31 AM)THE_Liam Wrote: Even on my 9mm Bosch I'm considering whether it's worth it. When I was in Cornwall I couldn't find any cheap veg so had to run diesel and it was like having a bigger blower, felt no different off boost but went like a rocket on boost, the pump just can't keep up with the demand for fuel on boost.
this is true to an extent, but as said before rapeseed is a lot better and with a little bit of derv thrown in it's not far off . .Smile
#55
I ran 250miles with diesel with the 2.1
now on 60/35/5 rapeseed/diesel/petrol with a little splash of 2stroke and some cetane booster....not noticed a difference
(27-09-2013, 01:58 PM)Piggy Wrote: I ran 250miles with diesel with the 2.1
But why go to all that trouble when you're going to see even less benefit in price difference by using derv, petrol, cetane booster and two stroke for what can only be described as not any different?
Throw diesel in, enjoy better mpg and be safe in the knowledge you aren't gumming stuff up and prematurely ageing seals.
Just my 2p...
#57
Just my 2p...
it just depends on what problems you encounter i suppose mate, better mpg's is codswallop tbh and i've been running veg for three years now with no real issues at all . .Smile
#58
two stroke oil is free for me. petrol n derv you would need anyway.
and cetane booster is about 0.5p for every 20litres!
(29-09-2013, 09:10 AM)csluyuan Wrote: ah...veg, that would have helped to know!!
_________________________
Buy Fifa 14 Coins
troll!!??
Buy Fifa 14 Coins
troll!!??
just getting his posts up by the looks . .Smile
  pistion advance setting of pump Bosch niciou 6 5,248 20-06-2016, 11:17 AM
Last Post: niciou
  Any tips for setting the pump up guys kev_boosted 5 4,409 05-11-2015, 09:07 PM
Last Post: kev_boosted
  Setting up a bosch pump bashbarnard 6 4,865 18-07-2014, 11:49 PM
Last Post: Martin306
