3 door right window regulator
Wanted: 3 door right window regulator
Hi all, I'm afer a window regulator for my 96 GTi6. Needs to match the plug as pictured, cheers Sleepy
[Image: qolv.jpg]
[Image: gakm.jpg]
[Image: h9bv.jpg]
Just noticed my phone camera sucks lol but hopefully you can make it out
Got to be someone on here breaking a 306 with 1 of these available? Huh
PH1 FTMFW!
anyone? Money waiting Cool
PH1 FTMFW!
I have a whole unit sat here £40 posted!
Ιts the 2 pin plug
[Image: ygaja9yd.jpg]
[Image: jy8enese.jpg]
Let me know bud
Just so you know I don't do paytheif only bank transfer, but many people on here can vouch that Iam trustworthy,
[Image: SDC10442-1.jpg]
That's not the same plug unfortunately Sad
PH1 FTMFW!
I could cut the connector off the door loom for ya
You can take the plug out of the motor and put your old one in. Its like an adaptor that just clips in.
Also, i can vouch that Jonny is trustworthy albeit an annoying old bastard!
Ha ha thanks nial!!! I think lol
I will try and have a look this week to see if I have got 1
Any luck frosty? Cool
PH1 FTMFW!
I should be going to my 306 stores tomorrow after work so I will let you know
Any luck frosty?
PH1 FTMFW!
I had a look mate but all the 1s I got are the square connector. I think the 1 you got is an aftermarket 1. I would say get a square connector 1 and get the plug with some wires on it and wire that in. You could take the 1 out of your d turbo
I really don't want to be chopping up the loom tbh or I would of done that already Sad, could it be a ph 2 or 3 connector?
PH1 FTMFW!
(17-09-2013, 07:04 AM)SKoob Wrote: I really don't want to be chopping up the loom tbh or I would of done that already Sad, could it be a ph 2 or 3 connector?
I've got ph1 and ph3 motors and there all square connectors. Was the motor reverted to the door?
Nope, was bolted on. Can't see any evidence of the door or loom being messed about with. Are there different plugs for 1 touch windows?
PH1 FTMFW!
I would say that as the motor was bolted on it has had a motor before which would say it had an aftermarket 1 fitted.
I think the motors are the same for the normal and 1 touch windows. The 1 touch 1s have different wiring and a control box.
I have a drivers door on the ph1 I'm breaking with working one touch electric window
You got a pic of the connections mate?
PH1 FTMFW!
  Wanted: phase 3 d/door window switch pug306driver 2 3,953 09-01-2021, 05:39 PM
Last Post: pug306driver
  Wanted: Passenger side window mech and door lock Piggy 0 2,102 07-05-2018, 05:22 PM
Last Post: Piggy
  Wanted: 5 door leccy window parts & switches Magenta Sunset 4 3,961 21-06-2017, 06:51 PM
Last Post: Magenta Sunset
