12-09-2013, 08:19 PM
doesn't it leak from where you've drilled for the threaded bar to go through?
Guide; Mid box to back box conversion
12-09-2013, 08:22 PM
Nah I used a few fiber washers wither side
I feel i should point out he doesn't actually know this, what with never having kept a car long enough to have to MOT it...
17-09-2013, 04:30 PM
Gonna try this one in the near future, when my mid-section is going to get replaced.
22-09-2013, 02:44 PM
I've just done this conversion earlier today.
I used an old exhaust clamp and put the threaded bar through it, with nuts and washers, like so... ![]() ![]() I also decided to stick a shiny exhaust tip on it. ![]()
26-09-2013, 03:43 PM
(22-09-2013, 02:44 PM)me-tm Wrote: I've just done this conversion earlier today. Thanks for that, I fitted mine using exactly this method last night in the dark, took half an hour. Sounds crazy now being straight through from the turbo!
27-10-2013, 07:00 AM
Iv welded in a centre box from a yaris. Shaped like a cherry bomb silencer, looks to have great flow inside and has quietened it down low down the revs like i wanted. Wasnt to sure were to fit it though so i welded it where my back box should be. Anyone know if the positioning of silencers makes any differance? I should imagine you would need it furthest away from turbo right?
19-11-2013, 10:50 PM
brilliant - have decat pipe & hopefully have a crack at the weekend - thanks for the guide!
Current - 306 ph1 xrdt - 323 estoril. History - Legacy Outback - Impreza Wagon - BMW 530 - Golf GTI mk2 - Escort TD - Audi 80 coupe - Astra GTE - Escort XR3
Project : http://306oc.co.uk/forum/thread-23625.html
20-11-2013, 02:07 AM
(27-10-2013, 07:00 AM)JJtheHITMAN Wrote: Iv welded in a centre box from a yaris. Shaped like a cherry bomb silencer, looks to have great flow inside and has quietened it down low down the revs like i wanted. Wasnt to sure were to fit it though so i welded it where my back box should be. Anyone know if the positioning of silencers makes any differance? I should imagine you would need it furthest away from turbo right? as far as i know each bend is supposed to change the note of your exhaust so would imagine it would
22-11-2013, 02:37 PM
So my mid-back box mk4 on my estate.
Cut the hangary bit off the original back box and used that and a massive jubilee clip to secure the mid box to the car then clamped on the original down pointing tail pipe.
26-11-2013, 06:31 PM
I'm not posting mine, it's that bad lol.
| Injector Pump Change Video Guide (Bosch Conversion) | darrenjlobb | 5 | 7,208 |
15-02-2013, 09:44 AM Last Post: Face. |
