Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
Thanks for the heads up c2k, but I can see the inlet valves are bent now the inlet is off, will find out the true extent of the damage when I get the head off.
Any no what could have caused it to slip on the front cam?
What's the best way to remove exhaust manifold?
Threads: 62
10
Given 11 thank(s) in 11 post(s)
08-09-2013, 08:06 PM
(This post was last modified: 08-09-2013, 08:08 PM by C2K.)
Exhaust manifold can be done from above but easiest from below, it's a bitch .
Perhaps Cambelt Snapped and was poorly timed. Where did you find the pullies?
![[Image: wallye-gtd.JPG?raw=1]](https://www.dropbox.com/s/pcxk1pgpaucznvr/wallye-gtd.JPG?raw=1)
HDi Owner for 200k/9 years
