266mm caliper bolts
Wanted: 266mm caliper bolts
I'm after the 2 bolts that hold the caliper/brake pad holder thingy to the hub need them for both sides (4 bolts) any one got some knocking around I can have cheap?
they the same as any other caliper bolt?!
I do have a set of 306 caliper bolts though if needed?
The 247mm bolts are a bit longer when I upgraded to 266mm I had to use a washer to make them fit
(31-08-2013, 09:28 PM)Piggy Wrote: they the same as any other caliper bolt?!
there different on the for the 106 i believe, are yours out of the 266mm brakes?
You mean the carrier bolts? I have a set of 266mm here you can have bolts if you'd like
(01-09-2013, 08:00 AM)aggyj17 Wrote: The 247mm bolts are a bit longer when I upgraded to 266mm I had to use a washer to make them fit
This if you mean calliper carrier bolts, I did exactly the same
[Image: siggy1.jpg]
you sure?!?!
I test fitted the 266s to my mrs and all the 106 bolts needed was a washer as already mentioned.
yeah I have 4 carrier bolts from 266 306 brakes.
think i will try the washers then get back to you i just under stood they was to long.
  Wanted: Caliper carrier bolts & abs sensor stuff mcglynn 7 3,113 31-10-2014, 09:06 PM
Last Post: mcglynn
  Lucas/Girling Caliper Carrier Pin or Caliper Carrier MY95 0 1,553 16-02-2014, 06:11 PM
Last Post: MY95
  Rear caliper bolts zekegti6 2 1,676 09-02-2014, 06:44 PM
Last Post: zekegti6
