19-08-2013, 06:21 AM
As above, need a lower steering column uj for the 205. Its for a power steering rack and is flat drive I think. Cheers!
Wanted: lower column uj for 205
19-08-2013, 11:25 AM
Same
19-08-2013, 01:57 PM
Oh dear haha, already decided i'm going to fab up a heatshield for it when I find on to put back in, should have had one as standard.
22-08-2013, 09:16 PM
I was lucky with mine £6 down scrappy, not easy to get though! Good luck
![]() Midnightclub Wrote:All the cool kids have ph 2 Nile 6's!
22-08-2013, 10:49 PM
(This post was last modified: 22-08-2013, 10:50 PM by Pugmarshall.)
I can get a whole column at the local scrappy for £30 but need to go and see what type it is, if it's the type you need ill let you know.
22-08-2013, 11:32 PM
I have a flat driver fitment one if you want it, not sure if its a power steering one or if it really makes any difference or not ?
23-08-2013, 06:39 AM
Power steering are different, I'm pretty sure
23-08-2013, 11:23 AM
Yeah they are, there are 3 types; Ph1 PAS, Ph1/Ph1.5/Ph2 non PAS and ph1.5/2 PAS.
26-08-2013, 07:17 AM
I may have one for sale depending if the cars getting broken or not.
Stage 2 XUD Sedan
26-08-2013, 08:23 AM
Mine is in fact spline drive, blame niall lol. Think i've managed to source a replacement joint, as in the cross-piece with accompanying bearings, so hopefully as good as new for less than £40, failing that got plenty of options now, cheers guys!
26-08-2013, 10:52 AM
Yeh I remember now, splined is power steering, flat isn't.
30-08-2013, 06:52 AM
Not sure if anyone's interested, but I ended up paying £28 for a new hardy spicer cross piece and took me a couple of hours to replace the old one, well worth doing imo considering the silly prices traders want for the whole shebang.
31-08-2013, 05:16 PM
I ended up cutting the original out and welding one from a 306 in. where did you get the new spicer?
31-08-2013, 08:02 PM
Local bearing specialist ordered it in for me, 38mm x 16mm if anyone wamts to do the same.
| Wanted: 306 lower steering column shaft/joint | 306clot | 2 | 3,162 |
16-09-2015, 05:09 PM Last Post: 306clot |
| Steering column/ UJ's | Tom | 3 | 2,491 |
14-08-2013, 07:55 PM Last Post: kernow_joe |
| Steering column | martyn92 | 8 | 5,776 |
23-04-2013, 05:58 PM Last Post: Bertman |
