Wanted: Ph2/Ph3 N/S Hub & Carrier
I'm after a good hub for a ph2/3 306.
Cheers.
16 or 18mm?
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
Ph2/3 so 18mm.
Measure first if I were you. Phase isn't always accurate
as far as I am aware all hubs are the same across the phases....the difference is the 16/18mm.
which theres no logic to, being french!
I have a pair of 16mm hubs
It's 18mm, I fitted the wishbones to it last year.
(23-08-2013, 10:08 PM)Pugmarshall Wrote: Ph2/3 so 18mm.
You say that but ph2 is 16mm.
It's about the turn of ph2.5 that they went to 18mm.
Just wanted you to clarify so that you didn't end up with someone with a ph2 16mm thinking they had what you needed Smile
Bianca Rallye
BMW Z4 3.0
I have one from the HDi I'm breaking...probably 18mm, I can measure if you want it Luke. Smile
as highlighted recently by another thread, there is NO particular way to identify the size by year, model or phase.
this being due to age and thus parts being swapped over time and good old Pug parts bin specials where all sorts of different ages had different sizes when new.
always check.
I fix these cars pretty much everyday, I know the deal James Wink
Like I said, I've measured it before.
Give me a week and ill have a pair of 18mm hubs
(26-08-2013, 11:45 PM)Pugmarshall Wrote: I fix these cars pretty much everyday, I know the deal James Wink
Been there, done that.
Measure twice, order once was the moto with balljoints in the Pug/Cit specialist I worked at for 6yrs.
Officially the parts books say 16mm for PAS and 18mm for non PAS. But we all know that doesnt work.
But if you know what ya got, thats the important bit.
Zakk knows this all too well...
£35 delivered
Bianca Rallye
BMW Z4 3.0
I have both sides one is f*cked il check tonight but 25 posted if pinch bolt isnt the one I has to cut
[Image: J5hxCcC.jpg]
I've got one now cheers! £18 posted Wink
No probs
(27-08-2013, 08:27 AM)Pugmarshall Wrote: Zakk knows this all too well...
wut?
Baw joyntz
  gti6 carrier and slide pin HDIkyle 1 2,229 17-08-2017, 02:29 PM
Last Post: humberas
  Wanted: Caliper carrier bolts & abs sensor stuff mcglynn 7 3,848 31-10-2014, 09:06 PM
Last Post: mcglynn
  Wanted: NSF GTi-6 carrier and slider pin Curt 4 2,924 13-07-2014, 11:57 PM
Last Post: Curt
