XU injector nozzles
XU injector nozzles
Hi all,
Does anyone know where I can get hold of a set of conical spray nozzles for a set of stock XU injectors? Obviously they have a split spray pattern for firing direct at the valves on the stock motor. The setup I'm currently running has the injector sat much further away so a split spray is not required.
Thanks,
JP
JP
Let me ask a quastion - are you not looking for injectors, but only conical spray nozzles? I've never heard about this kind of modernization, how should it work?
