Threads: 127
Car Model/Spec: 306 ph1 xrdt , Golf GTTDi 130
trying to remove my front bumper to put my splitter on, and the 3 bolts on the underside of the bumper with the long 'tabs' are rusted but spin freely without loosening off
can I just saw them off? Or will it make the bumper less secured to the body?
Threads: 198
135
Just f*ck them off. None of my bumpers have ever had them.
Threads: 151
14
Car Model/Spec: 306 D-turbo
Will make the bottom less secure but as pellowe said be fine without them
Team Doesn't own a 306
81
My bumpers did have them... now they dont... #reversing #toolow
Threads: 127
Might just gaffer tape them back together after, should do the trick
Abandoned ship anyway as its started to piss it down -.-
Threads: 151
14
So it is Ffs got to walk home soon!
Just cut them off closest to the nut then make a hole in the tabs and cable tie them round the lower cross member job done
Threads: 465
114
Car Model/Spec: Vauxhall
the bumper will sag and drop over time if you cut them off
you will get a big panel gap between the bonet lion and the bumper as the bumper twist down
Threads: 169
91
Just f*ck em off. I've never had any on any of the 6 front bumpers I've had fitted.
If you are that worried then make a new bracket with some metal bar and self tappers.
