13-02-2012, 12:00 AM
Hello whats this hanging down with a wire and metal thing near clutch pedal?
Where it ment to go?
Wire with metal hanging down near clutch pedal
13-02-2012, 12:02 AM
this was answered a few years back and for the life of me i cant remember what it was used for...
13-02-2012, 12:04 AM
If you look right at the back of the foot well, you will see a small hole it goes into. You will need to straighten it up though as its bent.
It's a temperature probe for your "climate control"
13-02-2012, 12:05 AM
Jonny b Wrote:Wasn't it something to do with the heaters like a probe something like that, i know it wasnt anything essential but an added option... iirc, it was put down to "Is everything still working, if so, dont worry.."
13-02-2012, 12:09 AM
NiallHarper Wrote:If you look right at the back of the foot well, you will see a small hole it goes into. You will need to straighten it up though as its bent. How does the climate control work or what does it do?
13-02-2012, 04:49 AM
Means you can make it rain or snow, or anything like that really. Or at least that's what it should do, what it actually means once you've removed the marketing bs, is "blowers" lol.
13-02-2012, 07:57 AM
Poodle Wrote:Means you can make it rain or snow, or anything like that really. Or at least that's what it should do, what it actually means once you've removed the marketing bs, is "blowers" lol. this, apart from it keeps the cabin at a constant temp, your temp dial will have *C round the edge of it IIRC ![]() But yeah, I remember that thread, it was, as said already, a probe for the climate control from a duct in the drivers footwell.
13-02-2012, 08:59 AM
its the shear pin that holds the steering columb together
13-02-2012, 09:29 AM
NiallHarper Wrote:If you look right at the back of the foot well, you will see a small hole it goes into. You will need to straighten it up though as its bent. I will straighten it up then put the probe sensor in the hole.
13-02-2012, 03:32 PM
I have had this on all my cars, I was sure i read that the sensor for climate control was in the console on the roof but might be wrong.
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
13-02-2012, 03:35 PM
HDIkyle Wrote:I have had this on all my cars, I was sure i read that the sensor for climate control was in the console on the roof but might be wrong. This is the sensor for the air temp in the ducting coming out of the vents IIRC
13-02-2012, 03:53 PM
Im surprised we managed to get to February for someone to ask this
next it will be the pipes off the fuel filter and header tank
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
13-02-2012, 04:53 PM
Peugeot Anal probe for Mice/Similar sized furry creatures, optional extra apparently.
13-02-2012, 07:19 PM
Were the end of the probe facing to the right there a rubber gromit. I straighten it out the probe and it pluged in there job done.
thanks everyone. |
| wire identification | pug306driver | 0 | 1,761 |
04-12-2019, 10:53 AM Last Post: pug306driver |
| Wire thickness for cooling fan | philpemberton94 | 3 | 2,575 |
17-04-2015, 04:47 PM Last Post: philpemberton94 |
| Random Wire Off Starter | Eddleston | 3 | 2,856 |
03-12-2014, 04:42 PM Last Post: Niall |
