weird tyre wear
my ph1 dturbo is standard and recently starting wearing the nsf outside of the tyre. im getting a strange knock every so often on that side? any ideas
[Image: cornishmafia.jpg]
I think you have answered the question!
worn suspension component causing knock, thus causing tyre wear!?!?
would a top mount cause this mate?
(02-08-2013, 09:14 PM)paul7278 Wrote: would a top mount cause this mate?
Nope. More than likely wishbone.
jack it up and check all for play and movement
f*cked balljoint or track rod end. My money is on balljoint
Worth just changing everything, track rod end, ball joint, p bush, front bush, as it prob all tiered and worn
  Uneven rear tyre wear rydon 12 8,236 13-06-2019, 04:18 PM
Last Post: Nexus
  Michelin PS3 Wear Rate MY95 9 6,793 23-03-2014, 06:23 PM
Last Post: MY95
  Break wear sensors Toast 4 3,300 19-05-2013, 05:15 PM
Last Post: Connor
