I had mine fixed the other week. It wasnt fully gassed as Kwikfit set a limit on how much gas they will use on a regas which will rarely fill the entire system from empty.It was very nice and cold! This was right in the middle of 30 degree heat as well and i was more than comfortable with the windows up.
Threads: 2
Right I will have a look at mine then thanks
Threads: 80
Car Model/Spec: 2006 Honda Civic 1.8 VTEC Ex
Given 5 thank(s) in 5 post(s)
If you are obsessed with MPG, dont bother.
If you like comfort, look into it!
There is a very common weak spot, where they always go. Also, try an indie air con company rather than peugeot for the pipes, as they are £ra*e.99 from peugeot.
