headbolt torque without angle gauge?
Been trying this for 20mins and cant work it out, i cant get the spring and the cup to stay in the bottom of the mount whilst trying to the bolt holes to line up, everytime i push down on the mount i either get to a point where its stuck or the spring pings out the bottom and i have to take the mount out and start over! Help please i wanted to get the head on today Sad
It can be tricky, I made a little tool that slots into the 2 bolt holes at the bottom of the engine bracket and holds the plunger in place. I assemble the bracket, plunger and tool on the bench then put it on the car. Remove the tool from the bracket once the tensioner is in situ. This is what is recommended in Haynes as far as I recall.
I have also used length of 8mm rod bent at right angles at the end, which allowed me with some difficulty to pull the plunger up so I could get the tensioner on, but a lot more fiddly than the above method.
Making tools isnt really an option for me :/
got any pics...cant think what you are working on
It should be possible to make a plunger-holder-backer with some of this and a couple of M8 bolts:
http://www.diy.com/nav/fix/hardware/iron...Id=9293623
...I'll try and get a picture of my bodged up one when I get home.
Sorted now. Another darrenjlobb video to the rescue.... headbolts! 30nm 70nm then 120degrees.... i dont have an angle thing so barry then up tight?
Has the title of the post changed Huh
Headbolts, I would be careful with these. Isn't it 220 you want? An angle gauge in Halfords isn't too expensive, but I have done it before using a protractor and some tip-ex to mark the amount to be turned through. This could be difficult depending on access around the engine. Best do it properly, you really don't want to cut corners at this stage.
Im thinking quatter turn on them all which is 90degrees then another "bit" so its nearenough to 120 :/ not like it matters if they're a bit tighter??
You wanna go careful, im pretty sure you turn them x amount of degrees and then after another x amount of degrees
Just do them all to torques, then do them all 90 (put breaker bar on, pick a point 90 degree (rightangle) away from wher eyou start, and do them all, then do them all half of 90 and ull be fine.
[Image: sigi-2.png]
The pdf we have stickied at the top of this section says 30, 70 and 120degrees so i done upto 70 but then was looking for an answer like Darrens which is spot on so cheers guys Smile
What do people use to tighten head bolts. I did mine to the torques but when on the angles the bit i have just twists and looks on the verge of snapping.
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  ARP Headbolt group buy blinkyeatu 2 1,775 13-01-2016, 03:50 PM
Last Post: Piggy
  Keeping the angle right? Wor Jimmy 0 1,504 01-03-2014, 05:52 PM
Last Post: Wor Jimmy
  exhaust angle in degrees?? Piggy 2 2,467 13-08-2013, 01:04 PM
Last Post: Piggy
