Spoiler fitting
Spoiler fitting
Whats best stuff to use to fit spoiler to car?
if its a bolt on one...nuts!
No its not bolt its phase 3
tigerseal
This ^^
weird...I got a ph3 one with bolts?!
The 2 screws it comes with?
It didnt come with bolts
If its got screw holes and your boots got the holes you can get the screws from pug for about a quid each iirc
I just bolted mine on, it came with the screws, but as said above there are pretty cheap from pug. I just put a blob of grease on the holes offered up the spoiler to the car, and then took the spoiler off and the grease left a mark where the holes needed to go, drilled the holes in the boot lid , and job done.
It all depends if you have the holes in the glass as to if you can bolt it on. Tiger seal would be a better bet than drilling glass if you don't have the holes IMO.
you dont need to drill the glass! lmao
As above if it is a phase 3 one as the OP says then you drill the bootlid, iirc it is the earlier phase ones that go through the glass.
(16-07-2013, 08:04 PM)titch Wrote: As above if it is a phase 3 one as the OP says then you drill the bootlid, iirc it is the earlier phase ones that go through the glass.
Correct. But I dont like idea of drilking through my boot. So tigerseal arraived today
  Fitting Phase 3 Spoiler philpemberton94 6 3,106 28-07-2014, 08:18 AM
Last Post: philpemberton94
  gti spoiler fitting... Piggy 8 4,003 17-02-2014, 04:54 PM
Last Post: Connor
  Fitting a rear spoiler... (Pics inside) silestanix 15 16,735 08-04-2013, 05:04 PM
Last Post: maxlee
