Wanted: 266mm brake calipers and 22mm master cylinder
As above looking for some good 266 calipers must be good condition with free bleed nipples, be nice if they come with good discs and pads??
Also need a 4 port 22mm master cylinder or something like that
What you got? Cheaper the better Wink
Pick up from pugfest or fcs would be best to save on postage
I got some 266 front brakes. They came off a hdi and have good discs and pads. Just surface rust on the discs which will clean up with use. I will upload a pic later if your interested?
Yer defo interested mate free bleed nipples? And you comeing to pugfest/fcs? How cheap are they Tongue
got a 22mm ms, but its only 2 port
(10-07-2013, 06:26 PM)zx_volcane Wrote: got a 22mm ms, but its only 2 port
Won't be any good for me thanks anyway
Good man, they stop uber well in a nad lol
You do know you need to grind a bit of your carrier away to make them fit yes?
(10-07-2013, 05:06 PM)Chris_90 Wrote: Yer defo interested mate free bleed nipples? And you comeing to pugfest/fcs? How cheap are they Tongue
I will check the bleed nipple. I will be going FCS and £20 no lower. Will load a pic up in a sec
[Image: null_zpscef2cae2.jpg]
Ok mate will have them off you at fcs if bleed nipples are free
I will check tomorrow and let you know
(10-07-2013, 09:57 PM)Frosty Wrote: I will check tomorrow and let you know
Ok mate thanks
Got the full brake setup off my hdi mate?
(11-07-2013, 11:31 AM)tbaxter08700 Wrote: Got the full brake setup off my hdi mate?
Has it got 4 port master cylinder?
you wont find a 4port from a 306 bud.
(11-07-2013, 05:39 PM)Piggy Wrote: you wont find a 4port from a 306 bud.
Ohhh you no we're I can get one from? Was tempted with 23mm but just don't want a solid pedal rather have a bit of feel to it
duno much on the 106 scene....what about a 106 gti M/C?! is that 22mm?
I love my 23mm. awesome. with the 5.1 fluid and braided lines feels like you are actually in control.
The bleed nipples are all free mate. So you defo have them?
(11-07-2013, 05:54 PM)Piggy Wrote: duno much on the 106 scene....what about a 106 gti M/C?! is that 22mm?
Might go for 23mm are 306 gti6 4 port?
(11-07-2013, 08:28 PM)Frosty Wrote: The bleed nipples are all free mate. So you defo have them?
Yer will have them mate pick up from fcs?
yeah thats cool. Are you camping with oc?
also gti6 mc are 2 port. no standard mc is 4 port as far as im aware
(11-07-2013, 08:47 PM)Frosty Wrote: yeah thats cool. Are you camping with oc?
I'm not Will be on 106 stand tho comeing down on the Saturday morning will inbox you my number when it's closer so I can meet you there some were to get them off you.
And ok there must some 4 port ones got that's what the 106 guys use have to look in to it abit more
yeah no worries
Wanting these asap if any one local got a set up that I can collect would be best????
You should of has the 1s off me. Though I have still got them
(04-08-2013, 07:32 PM)Frosty Wrote: You should of has the 1s off me. Though I have still got them
I've messaged you?? Before I bumped this up you not got it??
Replied
Still needing these
have you considered getting a 106 gti MC which is two port and just plumb it with additional pipe work?
Chris ive got a good set of 266 callipers with discs and pads sitting in the shed that i will never use. Yours for £30 plus postage.
Cant really compete with these but got some 266 calipers on there own in hammerite yellow id let go for 25 posted with fees covered?
(05-08-2013, 09:52 AM)Piggy Wrote: have you considered getting a 106 gti MC which is two port and just plumb it with additional pipe work?
I have yes but tbh rather have a 22/23mm 4port to save the hassle, all though I have thought about a 23mm 2port and get some exact braided lines up with brake bias valve for rears so they don't lock up, bit not sure what that would cost
(05-08-2013, 11:38 AM)Niall Wrote: Chris ive got a good set of 266 callipers with discs and pads sitting in the shed that i will never use. Yours for £30 plus postage.
Depending on price on postage may be interested? And if the bleed nipples free?
(05-08-2013, 03:54 PM)Jaymes306 Wrote: Cant really compete with these but got some 266 calipers on there own in hammerite yellow id let go for 25 posted with fees covered?
I will keep that in mind thanks
Postage will probably be about £10-15. Will weigh it all tomorrow for you Smile Also, the nipples were free last time they were used but they have sat for a few years. Cant see them seizing up though sitting in a dry shed!
  266mm calipers roland rat 5 5,369 10-10-2017, 01:48 PM
Last Post: roland rat
  Wanted: 23mm master cylinder Chris_90 8 5,932 28-05-2017, 04:29 PM
Last Post: Chris_90
  Wanted: 23mm 4 port master cylinder Chris_90 2 2,981 11-01-2017, 08:14 PM
Last Post: Chris_90
