08-07-2013, 05:22 PM
Anyone know what size/type of thread is on the td04 manifold?
Looks like m10 but doesn't fit. Imperial?
TD04 Turbo Manifold
08-07-2013, 05:31 PM
M10 x 1.25 not a regular 1.5 thread. If thats the original stud that is
08-07-2013, 06:10 PM
Any idea where I can get a couple apart from eBay because you have to but a pricey pack
08-07-2013, 06:28 PM
i used to live in wycombe, and always used bee-fast fasteners, in cressex industrial estate, for that kind of thing. they'll probley just give you them for free
306 XUD9 gt2052s
306 hdi stage 2 (hdi tuning) 205 STDT -new project
08-07-2013, 06:40 PM
(This post was last modified: 08-07-2013, 06:55 PM by scottbmxer.)
Thanks for the help tom and ryan!!
While I got the thread open I might as well clear up two things Will I need to blank this as I took the wastegate actuator off and weld it shut The other thing was what are these for as it already has a oil feed on the left side and return/drain on the right side (opposite)
08-07-2013, 06:59 PM
Yes blank that if it the gates welded and those are the water cooling holes so ignore them lol
Stage 2 XUD Sedan
08-07-2013, 07:07 PM
(This post was last modified: 08-07-2013, 08:45 PM by scottbmxer.)
08-07-2013, 09:08 PM
cut an inch of tubing. put one end over the pipe and zip tie/clamp a bolt in the open end, that normally works
or just squash the pipe (might not seal 100% tho) and/or use chemical metal i the hole
306 XUD9 gt2052s
09-07-2013, 06:46 AM
I got bolts for the studs from ebay, 6 for not much at all.
You do need to seal that hole up, I used instant gasket in mine, then a small piece of hose with instant gasket to make sure it was sealed. Are you going to be using any gaskets?
09-07-2013, 07:08 AM
Holts firegum exhaust paste. f*ck gaskets for a laugh. I never blocked my waterholes just left them.
09-07-2013, 07:47 AM
09-07-2013, 09:31 AM
I brought a gasket for the t2 manifold where it goes onto the engine but the turbo itself and all the plates - I was just planning on using holts exhaust paste as I've heard it seals a treat
I'll try putting some on the small turbo pipe and capping it off with a small silicone hose, cheers
09-07-2013, 06:36 PM
(09-07-2013, 09:31 AM)scottbmxer Wrote: I brought a gasket for the t2 manifold where it goes onto the engine but the turbo itself and all the plates - I was just planning on using holts exhaust paste as I've heard it seals a treat I did both so I was sure it was sealed, didn't want to take it off again. |
| Will a T2 turbo fit on a K14 manifold? | Dum-Dum | 3 | 5,715 |
18-05-2017, 10:00 PM Last Post: Dum-Dum |
| Td04 air intake size on turbo | Paul_13 | 8 | 4,945 |
19-09-2014, 05:15 PM Last Post: Ruan |
TD04 Turbo Info please!! | scottbmxer | 33 | 22,479 |
08-06-2014, 08:08 PM Last Post: sweeney1987 |
