Uprated rubber for my big pipe.
My 3" exhaust is a bit big in the exhaust tunnel and I want to reduce movement to stop it knocking on the rear bumper and heat shield.
Has anyone used the powerflex exhaust rubbers?
Or is there any other options? I was thinking of sandwiching the current mounts between two bits of conveyor belt rubber, which is quite stiff and might help.
Anyone got any other thoughts?
Not 306 ones but the land rover power flex ones are fecking hard rubber. If they are the same they will do the job
Cable ties? Wink
Wrap the exhaust in blankets. That will work right?
Speed shack do good hard PU ones, about £2-£3 each IIRC, reckon you'd get for a tenner posted if you were nice
I mis-read the title.
I was seriously expecting a thread about bag-pipes
I have used powerflex exhaust mounts tho, and they're a f*cking pig to get on unless everything lines up perfectly.
There is zero give in them, you can warm them up in a kettle to make it abit more pliable but it's still a massive ballache.
Just got new ones from unipart. Massive difference, they're much stiffer.
Hose clamps are ideal IMO. stop movement and are adjustable so you can get it sitting exactly where you need it
Stage 2 XUD Sedan
Aye Max but you want a bit of give or you'll crack welds after a while
Well hopefully I've sorted it with new mounts, the old ones were a bit perished TBH
i welded a bracket with a plate onto the original hangar points, another plate welded to the exhaust then bolt the two together. keeps the exhaust nice and tight to the tunnel
std halfords exhaust rubbers £1.99
hose clip around the outside £1.30
or with trade card
£1.20 + 70p
works a treat
