302mm discs
Does anyone (dumdum?) know if the 302s from the 307 are the same width and offset as the Gti 283s? I'd like to get some 302mm discs for my high specs but really can't be bothered making custom mounts to move the calliper over. If the 302s are right, I can just buy new mounts fom hispec
Gimmie a tick and ill find out, have a felling that they are both a couple of mm thicker and a couple of mm different offset.
Edit;
GTi6 disc height is 27mm and thickness is 22mm
302mm disc height is 34mm and thickness is 26mm
Cheers bbz. Would rather find some 300mm discs that are the right size rather than me buying bells and rotors as that is fooking expensive!
You will need to change the width of the caliper and maybe the adaptor.
I asked hi spec about it years ago, but then got put off my the increase in weight of the disc.
(09-07-2013, 10:40 AM)Niall Wrote: Cheers bbz. Would rather find some 300mm discs that are the right size rather than me buying bells and rotors as that is fooking expensive!
*cough* rep *cough*
The 302mm discs are substantially heavier. You wont find a pug fitment disc bigger than 283mm thats right for your calipers though.
  302mm vs GTi6 brakes Jonny81191 89 41,213 08-02-2012, 09:29 PM
Last Post: jammapic
  Brake disc weights. 6 and 302mm. Pompey306mark 5 4,662 13-12-2011, 06:44 PM
Last Post: Pompey306mark
