help xud diesel knocking :s
my new 306 engine started to develop a diesel knock its all matches up to tdc it idle fine and boost fine HELP
(04-07-2013, 07:54 PM)Teddy Wrote: my new 306 engine started to develop a diesel knock its all matches up to tdc it idle fine and boost fine HELP
I see.....
Maybe the pump is advanced too far?
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
tried tilting the bump back and forwards just the same could it be a bad injector ?
does it go away when you pump the primer grenade??
you on veg?!
no still there no on normal diesel
u can here it slighty when it idles but if u rev is suddenly its starts knocking but when u slowly build the revs it goes
Checked the oil?
oil is just bellow max i have a vid how do i uplaod it ?
http://www.youtube.com/watch?v=nLJR0HQKP...e=youtu.be there is video link lads running out off ideas engine never did it before when i had it in my old 306
Sounds a bit like an injector knock
might borrow some injectors tommorow see if it changes cheers for ur help lads
you should see signs of injector/diesel knock with what comes out ya exhaust!
I had this about two days ago after swapping to bosch retarded the pump and solved it.
if its the same as mine it doesn't make a noise while engine breaking eithir.
That sounds just like injector knock, a popper could be blowing its steam early before the others. It doesnt sound advanced accross them all, just on one, hence at around 1500 rpm you can almost hear it like a misfire.
update: getting some injectors tomorrow had a look at me glow plugs and 2 are dead and one is missing the end so ordering new plugs surprised it started tbh
