22-06-2013, 09:54 PM
(This post was last modified: 22-06-2013, 09:54 PM by Piggy.)
Thanks...that doesnt say it covers ABS...
but further down it does say this:
"ABS warning lamp sequence check is no longer necessary and the RfR for ABS warning lamp not following the correct sequence of operation has been removed."
so...they dont even need a ABS light now?!
rep'd for the link by the way
Threads: 198
135
ABS belongs in the bin tbqfhwy. No ABS, no lamp, no confusion.
I wana bin my ABS.
Wondering if I put a timed light in for MOT test b of it pass? !
Threads: 34
Judging by the new mot rules unless you have a specifically modified car like in that link I put up so rally / track etc so cage buckets harness etc so modified for purpose. If you remove stuff it won't pass as there now looking for what was fitted as standard on the car or so I'm led to believe anyhow
Threads: 34
Apparently it'll come up on the computer when the put in the reg. I don't know personally just relaying what seems to be said on every forum of late same with cats etc aparently even if it can pass a emission test with decat it will still fail mot as it should technically have a cat as it was fitted as standard according to recent thread on gti6 forum. Either way i dnt like it lol
Threads: 198
135
It may well say "A 306 gti6 came with ABS as standard" but who's to say yours did from the factory? Could have been a customer request not to fit it. It's an arguing point anyway, unless they see the specific data sheet for that exact VIN they'd have a hard time proving something should be there that isn't. ABS isn't a legal requirement anyway, whereas a cat would be. I've seen advisories for things like "coilovers fitted" which is just being really really anal. Surely you should then get one for any pattern parts. 99% of cars would have a three page advisory sheet with non-OEM backbox, non-OEM bushes, non-OEM dipstick, non-OEM wheels, non-OEM bulbs etc.
Suppose it's just a good time to get to know your MOT tester, hey?
That link says don't even need to test the bulb anymore so can't see why they even look for the module!
