MOT tomorrow!!!
MOT tomorrow!!!
So, MOT is due on the 6th July; so I put the Rallye in Early for her inspection.
To say I'm nervous about it is an understatement, it's the first one in my care!!
Saturday Morning at 10:15 :p
Black mask Service
Pass! It's pretty immaculate
Will fail on paint work lol
Will fail on account of the spastic that drives it :p
So, i choose now of all times to give the car a Pre-MOT inspection before tomorrow and have found:
Engine Oil Leak
Gearbox oil Leak
Power steering fluid leak
Exhaust Leak
Not to mention some newly formed rust underneath the car Sad
Thankfully Ginge is popping over later with some exhaust paste to sort out the tiny gap i have on the mid section pipe.
Then, she might be ready for the MOT
Black mask Service
So, it's finally come round... Mot this morning!! Exhaust leak dealt with so let's see how she does!!
Black mask Service
How did it go?...
My coupe failed
Brakes binding on
Airbag cover on passenger side insecure
Yeah, it passed Smile with 5 Advisories:
1 - Windscreen has damage to an area less than 40mm circle outside Zone A
2 - Power steering component has slight seepage.
3 - Offside brake juddering Slightly
4 - N/S/F (rear bush) Suspension arm has slight play in a Pin/Bush
5 - Front brakes only just met the front brake imbalance requirements. It would appear that the braking system requires adjustment or repair.
number 5 is as a result of number 3. The tester reckons that the disc overheated at one stage when new therefore warping the disc.
Black mask Service
Where did you go to get it done?
Fast Track in Fratton mate, Smile I've heard about your worries about MOT'ing yours!
Black mask Service
Not a bad result
I think I have sorted by brakes. Bled the system and now the car rolls on a slope rather than sitting still!!!
As for the airbag cover that's not so easy, had to take half the dash out, which is easier said than done as its assembled out of the car and all the screws come on from the wrong direction!!!
Now to find a new cover!!
What worries do you have phil?
(22-06-2013, 08:39 PM)Pompey306mark Wrote: What worries do you have phil?
Where do I start haha
But the main one is the seat subframe does not fit in the damn car!
The others I'll get fixed before is tyres and wheel bearing
Then ... Emissions can't be too bad as I'll fiddle with pump
Mine's due again next month, and no doubt it'll fail on handbrake efficiency like it does every year Rolleyes
  Viewing new car tomorrow.. revealed ginge191 25 12,783 05-06-2016, 08:28 PM
Last Post: ginge191
Thumbs Up That's it now FCS tomorrow Xsikid 2 2,506 03-06-2016, 08:31 PM
Last Post: insomaniac45
  Tomorrow! Dum-Dum 6 3,692 02-06-2016, 03:44 PM
Last Post: toseland
