Threads: 4
Hi, so bought the 306 previously stated in the posts, found few minor faults;
Rear wiper doesnt work
Boot is not locking- is it possible for the boot to be locked with the key. Have manually locked all 4 doors apart from boot.
Any ideas?
Threads: 25
Car Model/Spec: Vectra & Berlingo
Given 5 thank(s) in 5 post(s)
Sounds like cables that run in the black flexi tube in corner of boot lid is broken .
Threads: 4
(20-06-2013, 08:18 PM)306carter Wrote: Sounds like cables that run in the black flexi tube in corner of boot lid is broken .
for wiper motor? Im more concerned in the boot first i need to get the lock working as I stay in a shithole (Glasgow)
Threads: 141
35
its a phase 1 306 right? the bootlock has a key hole in it so hopefully thats sorted, although phase 1 boot locks do have an annoying habit of seizing, squirt a shit load of wd40 in there see if that does anything, if not take it apart (carefully!) and grease it all up
Threads: 4
(20-06-2013, 09:27 PM)ozonehostile Wrote: its a phase 1 306 right? the bootlock has a key hole in it so hopefully thats sorted, although phase 1 boot locks do have an annoying habit of seizing, squirt a shit load of wd40 in there see if that does anything, if not take it apart (carefully!) and grease it all up
Tried working the WD into the lock last night, hopefully it has improved some. How do i get in about the lock? Is it under the wiper motor?
Threads: 208
60
Im not sure they are even a lock are they? My ph 1 had a key hole that you could put a key into.but no form of lock mec on the back of it. Wtf is that about? Most pointless feture ever lol
Threads: 541
124
Could well be the car has had a new boot and the wiring hasn't been done.
Look behind the O/S C pillar trim and see if all 3 plugs are plugged in then check they are getting voltage at the appropriate times.
Then take the panel off inside the boot and check the wiring there. There's only 2 wires for the locking and 4 for the wiper motor plus 2 for the heated rear window.
If your definitely getting voltage to everything at the appropriate times then check the earth point on the N/S C pillar
Threads: 141
35
(21-06-2013, 11:55 AM)puglove Wrote: Im not sure they are even a lock are they? My ph 1 had a key hole that you could put a key into.but no form of lock mec on the back of it. Wtf is that about? Most pointless feture ever lol
there is a lock in there, just doesnt do much, the locking mechanism is basically a triangle of plastic lol
Threads: 4
(21-06-2013, 07:52 PM)ozonehostile Wrote: (21-06-2013, 11:55 AM)puglove Wrote: Im not sure they are even a lock are they? My ph 1 had a key hole that you could put a key into.but no form of lock mec on the back of it. Wtf is that about? Most pointless feture ever lol
The heated rear screen is not working, new rear screen it is!
Threads: 4
(23-06-2013, 09:32 PM)306phase1Nreg Wrote: (21-06-2013, 07:52 PM)ozonehostile Wrote: (21-06-2013, 11:55 AM)puglove Wrote: Im not sure they are even a lock are they? My ph 1 had a key hole that you could put a key into.but no form of lock mec on the back of it. Wtf is that about? Most pointless feture ever lol
Boot is still seized, what did you use to undo lock mechanism?
wd40 or similar.
Im having all same issues (ph1).
once I get it open....currently locked shut...wiring will be first port of call.
do have a complete ph1 motor with relays though cheap if you want
Threads: 4
26-06-2013, 10:32 PM
(This post was last modified: 26-06-2013, 10:32 PM by 306phase1Nreg.)
(26-06-2013, 10:29 PM)Piggy Wrote: wd40 or similar.
How many miles has yours done? Mine has seized solid, try putting a plain screwdriver through keyhole, drench hole in WD and leave the boot open upright for a good few hours. Hopefully it works. And how much mate?
(26-06-2013, 10:32 PM)306phase1Nreg Wrote: (26-06-2013, 10:29 PM)Piggy Wrote: wd40 or similar.
Just remembered you cant get yours open. DUMBO lol
guna try it tomorrow.
its seized before. 145k
Threads: 4
(26-06-2013, 10:34 PM)Piggy Wrote: guna try it tomorrow.
Im on 197k
